derfnigel
Everything posted by derfnigel
  1. just put one in mine yesterday and it makes a world of a difference.Still cant shift at full throttle but it is way better than it was. :biggrin:
  2. i was wondering what the advantage of 4 mil stroker crank was and will it require a port job to be effective?Im doin a crank any ways and iv read abou the 795 and the longer rod for reliability.
  3. make sure its not that kick starter they are notorious for ratlling
  4. what about some bad bearings in the swing arm
  5. plug chop pics tell me what you think im guessing a little richer
  6. well i put v force reeds in this weekend. My bike was jetted spot on before.I did a plug chop and the ring is darker than before and farther up on the porcelaine, it is also narrower.I was hoping someone could tell me if v force 3 need a jetting change on a banshee sorry if this is a repeat question i searched the forums and found nothing.Thanks
  7. just ordered a blue tm one on friday thanks guys
  8. block off plate was the culprit was pushing on the park brake rod.
  9. sound reaally stupid i when to do a rear brake swap and i also cant get the pad to clear the rotor.I used a c clamp no luck ill try the bleader screw tomorow i am installing ebc FA84SV pads.
  10. whitecourt alberta trails pits lakes sand
  11. thanks ill have to order one
  12. if you use cheap oil you dont want to mix 50/1 the yamaha manual says 32/1 for yamalube 20/1for anything else =cheaper .The less oil you run the richer the mix more fuel for same amount of air not richer as in oil compared to fuel but fuel compared to air.I run castrol super 2 and mix 24/1 im jetted 280 w/o airbox lid, k&n and fatty pipes at 2500 elevation.Runs like a top
  13. Im lookin a getting a case saver any one had experience with one ?I was looking at tm deseign's
  14. thanks guys i ordered a 2" 7/8 to 1 1/8 rox riser
  15. does anyone run handle bar risers cause my bars just feel to low when im standing i was thinking of a 2 " riser
  16. sneeze could be carbs out of sync or a little lean if it was jetted for summer
  17. you should be able to run premium up to about 160 psi
  18. derfnigel
    paddles
    yup thats how i mounted them i just though since they are directionnal it might pull to one side or something
  19. derfnigel
    paddles
    there is a right paddle and a left i have 2 of the same left side.http://www.kendausa.com/atv/sand.html
  20. derfnigel
    paddles
    i have kenda trakkers 20x12-10 but they are both part #k296.They should be ran as a pair 296 and 297 what will running 2 296 paddles do ?I got them for free.im just wonderin if i should go get a 297 from the local dealer or if its not that big of deal
  21. my front's are 23" kenda klaws and i got 22" mudlights s in the back
  22. would that banshee still have the tors setup so you can't rev it if the parkin brake is on
  23. i just put a new head on my shee and the difference in throttle response is sweet i went from 108 psi to 140 with 19 cc domes.It seems to give you way more torque i love it i will be gettin a set of 18 cc soon.
  24. i drilled 3/4 "holes in the top of mine i thimk 6 in total just don't go too far back and took the snorkel off.Works good but i preffer running no airbox lid but i bring it with me if im doin a lot of water crossing. o yhea it got 2 layers of plstic only drill through the 1st one.
