bansheeigo Posted October 22, 2006 Report Posted October 22, 2006 I was wondering what the torgue spec was on the axle nut?, I bought it in 99 and also wondering if it was the same now than it was then(torque that is)? Thanks for your answers. :biggrin: Quote
Bansh-eman Posted October 22, 2006 Report Posted October 22, 2006 i cant find my clymers but i want to say its like 160 lbs but that dosent sound right... i juts put a pipe wrench on the lock nutz and step on it until it stops moving .... use some red loctite it wont come off.. Quote
locogato11283 Posted October 22, 2006 Report Posted October 22, 2006 are u serious? who cares. just wrench that thing down tight and go ride.. Quote
BigRed350x Posted October 22, 2006 Report Posted October 22, 2006 BIG impact gun and a really loooong socket. LOL I do the pipe wrench thing too, with loctite. Hasn't failed me yet. :laugh: Quote
differentstrokes Posted October 22, 2006 Report Posted October 22, 2006 (edited) You don't have the lonestar locknut? You don't have to worry about tightening it near as much since it has pinch bolts to keep it from working loose. But like everyone said, just loctite it and forget it. Edited October 22, 2006 by differentstrokes Quote
locogato11283 Posted October 23, 2006 Report Posted October 23, 2006 i never have and never will use loctite. its got a spot for a cotter pin. just put that in there. mines been like that for years now with no issues.. Quote
Bansh-eman Posted October 23, 2006 Report Posted October 23, 2006 i never have and never will use loctite. its got a spot for a cotter pin. just put that in there. mines been like that for years now with no issues.. axcalibar dosent have a hole for a cotter pin... or at least mine dosent... Quote
BigRed350x Posted October 23, 2006 Report Posted October 23, 2006 axcalibar dosent have a hole for a cotter pin... or at least mine dosent... Aw, just drill your own hole then! Ha ha Ha! Quote
bansheeigo Posted October 23, 2006 Author Report Posted October 23, 2006 I'm not worried about it coming off, and yes mine has cotter pins on them. I just want to know how much foot pounds of torque to put on them without them coming loose and my hubs(stock hubs) move a little bit back and forth.If I use loctite on the threads which one should I use, RED or,BLUE? Thanks for your replies. Quote
black sunshine Posted October 23, 2006 Report Posted October 23, 2006 I'm not worried about it coming off, and yes mine has cotter pins on them. I just want to know how much foot pounds of torque to put on them without them coming loose and my hubs(stock hubs) move a little bit back and forth.If I use loctite on the threads which one should I use, RED or,BLUE? Thanks for your replies. The clymers manual recommends RED, I myself used blue this spring and havent had any trouble with them working loose; just make sure the threads are CLEAN!! Do you have the axle nut wrenches? If not the torque values are meaningless. Inside nut to 40 ft*lb Hold inside nut and tighten outside nut to 140 Draw a line across both nuts. Hold outside nut while turning the inside nut against the outside nut (jamb) to 177 ft lb. Measure the distance between the two lines you have drawn. If it is less than 3mm, repeat until a distance is gained of a min of 3mm. That is paraphrased from the clymers manual. Otherwise, grab a couple pipe wrenches or 18in crescents and your loctite. Oh, and spent 30 bucks on a clymers and you wont have to wait for days for someone to do this for you :beer: Quote
locogato11283 Posted October 23, 2006 Report Posted October 23, 2006 axcalibar dosent have a hole for a cotter pin... or at least mine dosent... oh well then thats out..loc tite and go!! :beer: Quote
Bansh-eman Posted October 23, 2006 Report Posted October 23, 2006 Aw, just drill your own hole then! Ha ha Ha! im not worried about it i just put a pipe wrench to it and stomp on it , and use some red loctite I'm not worried about it coming off, and yes mine has cotter pins on them. I just want to know how much foot pounds of torque to put on them without them coming loose and my hubs(stock hubs) move a little bit back and forth.If I use loctite on the threads which one should I use, RED or,BLUE? Thanks for your replies. use red its "permanent" you can bust it if need be using another pipe wrench Quote
bansheeigo Posted October 24, 2006 Author Report Posted October 24, 2006 (edited) Black SunShine, I'm not talking about the locknut that holds the axle on the swingarm, I'm talking about the nuts that go on the ends of the axle that hold the hubs on.I threw those stock ones away along time ago. So Red loctite is ok to put on the threads(end of the axle)of the axle so they won't get loose, but does anybody know how muck foot pounds of torque go on the nuts? thanks for your replies. Edited October 24, 2006 by bansheeigo Quote
black sunshine Posted October 24, 2006 Report Posted October 24, 2006 Black SunShine, I'm not talking about the locknut that holds the axle on the swingarm, I'm talking about the nuts that go on the ends of the axle that hold the hubs on.I threw those stock ones away along time ago. So Red loctite is ok to put on the threads(end of the axle)of the axle so they won't get loose, but does anybody know how muck foot pounds of torque go on the nuts? thanks for your replies. Sorry about the double post...oops! 88 ft lbs but that is for a stock axle. I just got a lonestar a few months ago and there was no literature with it (it was new from the factory) so I guess theyre the same. Says nothing about loctite but if you dont have the castle nut/hitch pin set up it may not be a bad idea. :shrug: Quote
Bansh-eman Posted October 24, 2006 Report Posted October 24, 2006 Sorry about the double post...oops! 88 ft lbs but that is for a stock axle. I just got a lonestar a few months ago and there was no literature with it (it was new from the factory) so I guess theyre the same. Says nothing about loctite but if you dont have the castle nut/hitch pin set up it may not be a bad idea. :shrug: i miss read your post i thought you wanted the torque spec for the locknut, the hubs dont have specs i dont think... just run them up until your hubs dont wobble then go one more notch and pin it... Quote
