Guest WICKED ATV Posted July 27, 2006 Report Posted July 27, 2006 I was wanting to know if anybody had some pictures of there bottom case that was trenched for a 10mm stroker and can i just show it to a local machinist and get them to do it? Quote
locogato11283 Posted July 27, 2006 Report Posted July 27, 2006 i would have someone do it who really knows what they are doing...its a tight fit lemme tell you.. Quote
Animalman294 Posted July 27, 2006 Report Posted July 27, 2006 I agree with Loco, you should have it done by someone who does it. A local machine shop can probably do it, but the guys that do it all the time already know that they may need to take a little more material off this part of the case or that part. Take your chances, but how much is it going to cost you if it's not done right...................... :beer: Quote
KEVSWS6 Posted July 27, 2006 Report Posted July 27, 2006 I was wanting to know if anybody had some pictures of there bottom case that was trenched for a 10mm stroker and can i just show it to a local machinist and get them to do it? It takes a while but if you have time to burn its easy. I do mine by hand with a cut off wheel or grinder. If you accidentally cut through the case in a spot or two just use some epoxy on it. I use lab-metal http://www.alvinproducts.com/Products/Products.asp?id=1 This is the poor mans way make no mistake but I be poor. Here's a couple of pictures of a 7 mm I did. http://community.webshots.com/photo/209989...033666981RbWzBI http://community.webshots.com/photo/209989...033666981RNWvjE Quote
Rustbag Posted July 27, 2006 Report Posted July 27, 2006 Nice. Hey is that Lab metal like premixed JB weld? :biggrin: Quote
rtg_61184 Posted July 27, 2006 Report Posted July 27, 2006 hey just my 2 cents but take it to someone whos doen it before. they'll already have the setup down and guess work taken out. im a cnc machinst by trade and trust me i've seen these one off jobs come around quite a bit only to be scraped out by some fuck who should be working at mcdonalds and not machining. hope this helps Quote
KEVSWS6 Posted July 27, 2006 Report Posted July 27, 2006 Nice. Hey is that Lab metal like premixed JB weld? :biggrin: Just like it :smile: Quote
BigRed350x Posted July 28, 2006 Report Posted July 28, 2006 It takes a while but if you have time to burn its easy. I do mine by hand with a cut off wheel or grinder. If you accidentally cut through the case in a spot or two just use some epoxy on it. I use lab-metal http://www.alvinproducts.com/Products/Products.asp?id=1 This is the poor mans way make no mistake but I be poor. Here's a couple of pictures of a 7 mm I did. http://community.webshots.com/photo/209989...033666981RbWzBI http://community.webshots.com/photo/209989...033666981RNWvjE Props to a guy doing it himself! I do everything I can before I think about sending something out. I work in a machine shop though so I can do quite a bit of stuff in-house for free. It takes a while but if you have time to burn its easy. I do mine by hand with a cut off wheel or grinder. If you accidentally cut through the case in a spot or two just use some epoxy on it. I use lab-metal http://www.alvinproducts.com/Products/Products.asp?id=1 This is the poor mans way make no mistake but I be poor. Here's a couple of pictures of a 7 mm I did. http://community.webshots.com/photo/209989...033666981RbWzBI http://community.webshots.com/photo/209989...033666981RNWvjE Props to a guy doing it himself! I do everything I can before I think about sending something out. I work in a machine shop though so I can do quite a bit of stuff in-house for free. Quote
Guest WICKED ATV Posted July 28, 2006 Report Posted July 28, 2006 thanks for the help guys i will take it to someone who knows what there doing. Quote
