banshee87 Posted April 16, 2006 Report Posted April 16, 2006 ok here goes i have an 87 shee . it has fmf pipes 320 jets 34 mm kehin flat slides v force reeds 1/4 spacers .80 over k/n filter no lid on air box cool head vito racing intake 21 cc domes in heads useing br8es plugs roost boost intake and boost bottle are 1 piece i think thats all now for my problem and question at first it was blowing blueish smoke out the right side pipe all the time more throttloe more smoke then we synced the carbs and rejetted ran good but still light smoke now i ran it last night and it overheated i heard it bubbling in the radiator checked the coolant and it was low now it smokes really bad like a dark blue fog and smeels like shit i think it might be a crank seal on the right side now for the question do i need to split the case to change the crank seals or is there a way to do it without spliting it also i keep finding oil on the right side of my frame and on the bottom of the case it is trans oil im running amsoil 50:1 ratio i think thats all but i need help quick before my old lady freaks ive only had the shee about a month Quote
Wicked98Shee Posted April 16, 2006 Report Posted April 16, 2006 pressure test your engine, that'll let ya know the condition of your seals ... it should hold 6lbs for 6 minutes Quote
Ben350 Posted April 18, 2006 Report Posted April 18, 2006 Same thing happened to me last year. Right hand seal went out. Mine didn't overheat, though. Yes, you do have to split cases Quote
banshee87 Posted April 26, 2006 Author Report Posted April 26, 2006 ok here is what i found my drive gear on the end of the crank came loose and the nut shot through the case lost the w/p gear seal case cover and w/p bearing sucks total rebuild i guess first time for me any help to stop this from happening again Quote
FasterThanU90 Posted April 26, 2006 Report Posted April 26, 2006 87 before u start tearin it apart try just flushing all the coolant out that might be part of ur cooling prob and ur gonna need to reseal the cases thats why its leaking oil out the bottom their sealed form the factory but over the years it wears out of course, i had Jeff at FAST do it for me And i would richen up that premix i wouldnt trust that 50:1 Quote
banshee87 Posted April 27, 2006 Author Report Posted April 27, 2006 can i seal it wit yamabond you are talking about the bolts that go through the case out the bottom right Quote
batoutofshell Posted April 27, 2006 Report Posted April 27, 2006 if your case is cracked or broken in that area you have to replace it Quote
