northshore Posted March 31, 2006 Report Posted March 31, 2006 My left side fits tight, but when you put the springs on the right side, they are lose and dont fit tight, so when you rev it up, the pipe blows about 1/2 inch off of the cylinder and makes a horible rattling noise. any sugesitions, or is this a manufacture defect? Quote
Hilarious Posted March 31, 2006 Report Posted March 31, 2006 My left side fits tight, but when you put the springs on the right side, they are lose and dont fit tight, so when you rev it up, the pipe blows about 1/2 inch off of the cylinder and makes a horible rattling noise. any sugesitions, or is this a manufacture defect? 495116[/snapback] Have you tried some new springs? Just a suggestion. I did not have this problem when I had my fattys. Like you said, may also be a manufacturing defect. Check all your pipe hangers and make sure they are in good condition and tight. Quote
Tim C Posted March 31, 2006 Report Posted March 31, 2006 FMF sells a spring kit that comes w/orings for the exhaust - your dealer should be able to get it for you. They're about $15 Quote
northshore Posted April 2, 2006 Author Report Posted April 2, 2006 I have bought the kit from fmf many times now, and always the same thing, they dont even fit when they are new Quote
sandman Posted April 3, 2006 Report Posted April 3, 2006 I actually had the same problem with my Fatties. Mine was also on the right side & I believe it was the bottom spring. It's most likely not your springs but rather the ring is welded in the wrong spot on the pipe. I have had several brands of pipes & I can honestly say that FMF is probably one of the worst out there for quality. Whether it be rust, springs not fitting or the pipe splitting along the seam of the expansion chamber, & the pipe hanger welded on crooked thus resulting in broken pipe hangers all the time. I had all four problems with mine. Here is my .02 cents... please take it at face value. Sell your pipes on ebay & buy another brand, after that advertise for FMF like I am doing now!!!! Quote
Samdogmx Posted April 3, 2006 Report Posted April 3, 2006 mine have the same problems. The right bottom spring is not even close to being tight. Quote
chevdodge Posted April 5, 2006 Report Posted April 5, 2006 go to the hard ware store and get a shorter heavy spring... has worked on mine for the last 3 years... just a bitch to get it on and off. Quote
scuba147 Posted April 6, 2006 Report Posted April 6, 2006 I also went to the hardware store and bought heavy duty springs--works good Quote
