Guys,
While looking at my shee shift forks they appear to be a bit worn and need to be replaced. Since I am replacing the foks I am wondering if the RZ forks will work on the Shee drum? From what I have read most people replace both but am not sure if this is necessary. If replacing both is required is the improved shifting from the forks, drum or the combination. Please help.
Thanks for your help
Chris
yes they will work perfectly, i ran them in my drag bike, rz forks are beefier.and will not sharpen and thin like banshee forks.at least not as quickly.i ran rz forks, banshee drum.
RZ forks fit in my shee trans no prob, hell of alot beefer to!
Ok, Thanks guys,
So the next question is where can I fine new RZ shift forks? Per the Yamaha Fische I looked at last night the RZ diagrahm now calls out the shee shift fork part number.
Thanks
Chris
Ok, Thanks guys,
Thanks
Chris
477505[/snapback]
Yamaha does NOT make them anymore, they now spec Banshee shift forks for RZ replacements. Ebay is going to be your best bet. I actually found mine through a member here (thanks Jared).
