Lethaface Posted February 7, 2006 Report Posted February 7, 2006 (edited) Hi all, I recently got a 99 banshee in early december, after a couple rides and a complete loss of compression i now find myself in the process of rebuilding it..The rings are almost paper thin in some spots and thick in others..So after putting my finger in the spark plug hole and feeling no pressure i knew there was a problem..The compression is completly gone and will not even register on my tester..So i need to order myself a new set of piston-onies..I know i can get the pistons much cheaper on ebay, than my local shop ($200 without wp bearings), but am sorta confused on which size to get..I know that the old pistons are wiseco but wasn't sure on there size..After cleaning up the piston top's a bit i have came up with these numbers Dead in the middle of the piston centered is 513M06450 right underneath that is CD and the arrow.. On the complete opposite side of the piston there is C00D3 Does anybody know what size these ol pistons are? Any help would be greatly appreciated becuae i need to go ahead and order the next size up.. Thanks, Letha Edited February 7, 2006 by Lethaface Quote
wesw Posted February 7, 2006 Report Posted February 7, 2006 they are bored out to 64.5 so you need to go bigger. hope that helps Quote
FadedDreams Posted February 7, 2006 Report Posted February 7, 2006 64.50 is the piston size.That would be .020 over. Quote
Lethaface Posted February 7, 2006 Author Report Posted February 7, 2006 Kool, thanks..I think i will order me up some .040 over's tonight Quote
FadedDreams Posted February 7, 2006 Report Posted February 7, 2006 The next size would .030 over.I wouldn't bore it any more than that unless you have to. Quote
Lethaface Posted February 7, 2006 Author Report Posted February 7, 2006 yeah i knew 30 over was the next size..The only thing i was worried about was if it ended up having to be bored out to .040 becuase of wear..The guy who will be going the bore/hone is a couple states away so i thought it would be safer to do it that way..I will inspect it a little better tommorow and see how the cylinder walls look.. Quote
Lethaface Posted February 7, 2006 Author Report Posted February 7, 2006 yeah this was the rings..Hard to tell but one side was super thin..Pistons dont look 2 bad but there was some blow by.. Quote
batoutofshell Posted February 7, 2006 Report Posted February 7, 2006 i would get bigger new rings, cheaper Quote
banshee tuner Posted February 7, 2006 Report Posted February 7, 2006 Most builders sell piston kits so you can send your jugs off and have them measured and buy the piston kit from him. Quote
FIRST BANSHEE Posted February 7, 2006 Report Posted February 7, 2006 yeah i knew 30 over was the next size..The only thing i was worried about was if it ended up having to be bored out to .040 becuase of wear..The guy who will be going the bore/hone is a couple states away so i thought it would be safer to do it that way..I will inspect it a little better tommorow and see how the cylinder walls look.. 469774[/snapback] I would send the jugs, and let your machinest decied which size you need. he might be able to get them cheap. Quote
Lethaface Posted February 7, 2006 Author Report Posted February 7, 2006 (edited) I can get them for about 160 shipped off ebay that's why i was wanting to go about it that way..I wanted to get it ported while i had the thing completly tore apart but the builder i have been researching never awnsers his phone..Good suggestion though fellas i think i will try that.. Edited February 7, 2006 by Lethaface Quote
FIRST BANSHEE Posted February 7, 2006 Report Posted February 7, 2006 I can get them for about 160 shipped off ebay that's why i was wanting to go about it that way..I wanted to get it ported while i had the thing completly tore apart but the builder i have been researching never awnsers his phone..Good suggestion though fellas i think i will try that.. 469826[/snapback] eric gorr at foward motion answers his phone and any questions you might have. had great prices on parts and porting. I haven't read a bad thing about jeff at F.A.S.T either. Quote
Lethaface Posted February 7, 2006 Author Report Posted February 7, 2006 eric gorr is the builder i have been trying to call for 2 weeks..I actually got ahold of him once for like 2 seconds and he said "i am shipping some stuff off call back later" and never got ahold of the guy again..I guess i will just go with the guy who did my blaster motor..I wanted to try out somebody new, but if you can't get ahold of them to set up work, you can't trust your parts to be sent there(no disrespect intended) Quote
. Posted February 7, 2006 Report Posted February 7, 2006 are you getting porting? If your just rebuilding have a local machine shop do it. Quote
Lethaface Posted February 7, 2006 Author Report Posted February 7, 2006 I am for sure going to get the head milled/rechambered, I am still thinking about the porting.. Quote
