I bought a used cool head the other day, and i have a few questions on it. This is the first cool head ive put on a banshee, so, when you go to install it on the top of the jugs, you put the o-rings on the head then set it down. But do u still use the stock head gasket or no? Also how do u get the o-rings to stay in the head while setting it down on the jugs? Could this be due to needing new O-rings? If so where do i find O-Rings for a Chozen Preformance Cool head? Thers only 4 o-rings, the cylinder ones and the outter rings, Do u think these would be the same as the Mod Quad or Cool Head O-ring kits? NEED HELP I guess :confused:
You can get the O-ring set at your local dealer , as for what you have there :blink: it kinda sounds like you might be missing some ? There should be O-rings to go on the head bolts , and by the way you did get longer head bolts with that didn't you ? Anyway the O-ring set is like 20 or 30 bucks and yea it might be a good idea to go ahead and replace it since you allready got it apart and your not to sure if the O-rings you have are any good ? Hope this helps.. :cheers:
If you need replacement parts for the chozen head go to www.chozenperformance.com and white lithium grease will hold the o rings in, just a little though, and you for sure do not want to run your stock gasket on you cool head.
I bought a Oring kit from Chozen, i dont need longer head studs because the Chozen Cool Head is one piece. So waiting for them come friday and then the SHEE will live again :evil: Has not ran in 4 months, Had a little rebuilding to do to Her.... :bolt:
I left my stock head gasket on when i put my noss head on and havent had any leaks. Also put greese on the orings so they will stay in place.
469850[/snapback]
Wouldnt that give you the wrong height and mess up the compression a little?
Dont leave that stock gasket on there ! Its not suppossed to be on there , thats why your cool head comes with o-rings ..Not to mention the stocker is only good for one use ....
