badxr6 Posted January 8, 2006 Author Report Posted January 8, 2006 (edited) Pretty vauge question. What kind of pipes are you looking for? There are low-end, mid, top-end & overall pipes. This topic has been covered dozens of times, try searching. 456507[/snapback] mid to top end i have pro-circuit but was woundering if t5s were better Edited January 8, 2006 by badxr6 Quote
Long Rod Todd Posted January 8, 2006 Report Posted January 8, 2006 You're not going to get any poontang with those PT pipes go with the T-5's. Quote
Banchetta Posted January 8, 2006 Report Posted January 8, 2006 mid to top end i have pro-circuit but was woundering if t5s were better 456510[/snapback] Either you don't understand the difference or you don't know what you need.....You first said you wanted a set of pipes for the trails, which tells me that you need a lot of midrange w/ really good low end...a mid to top end pipe is worthless in the trails. Obviously you know that now since your pc pipes are dissappointing to you...they have no low end. For tight trails where in always in 1-4th gear, then go w/ the 2 into 1 exhaust. If you want the best low end pipe w/ twin exhaust then get the Pt mids from Duncan...they have incredible low end, awesome midrange pull and really good top end power. If your wallet can't afford them, then get the fmf gnarlies or sst's..they have decent low end, good midrange pull and decent top. Comparable to the pt mids, on midrange and top, but the mids pull better on the bottom. The T5's are no better in the trails then the pc pipes. They are both a high rev pipe.. Quote
crazywheelerman365 Posted January 8, 2006 Report Posted January 8, 2006 Pipes !! I've ran FMF Fatties and pro circuit platinum's with 304 silincers and needless to say my FMF's are still hangin on the wall.. Quote
96dragbanshee Posted January 8, 2006 Report Posted January 8, 2006 You say you are using these for trail riding i would definately suggest CPI pipes they have the best low to midrange power increase. If you plan to port these are definately the way to gol. They are better than toomys and cheaper the PT mids. Quote
badxr6 Posted January 8, 2006 Author Report Posted January 8, 2006 Either you don't understand the difference or you don't know what you need.....You first said you wanted a set of pipes for the trails, which tells me that you need a lot of midrange w/ really good low end...a mid to top end pipe is worthless in the trails. Obviously you know that now since your pc pipes are dissappointing to you...they have no low end. For tight trails where in always in 1-4th gear, then go w/ the 2 into 1 exhaust. If you want the best low end pipe w/ twin exhaust then get the Pt mids from Duncan...they have incredible low end, awesome midrange pull and really good top end power. If your wallet can't afford them, then get the fmf gnarlies or sst's..they have decent low end, good midrange pull and decent top. Comparable to the pt mids, on midrange and top, but the mids pull better on the bottom. The T5's are no better in the trails then the pc pipes. They are both a high rev pipe.. 456571[/snapback] most of the riding i do is top end riding more than bottom end riding and i thinking of puting in big bore sleeves and pistons as well Quote
dajogejr Posted January 8, 2006 Report Posted January 8, 2006 You say you are using these for trail riding i would definately suggest CPI pipes they have the best low to midrange power increase. If you plan to port these are definately the way to gol. They are better than toomys and cheaper the PT mids. 456670[/snapback] Huh??? Last I checked CPI and Shearer were top end drag pipes. I've never heard of a "bottom end" CPI pipe... T5s, Lightened flywheel and get an adjustable timing plate. Set the plate at +4...live happily ever after. Love my T5s, but they really started to shine in the trails with the timing and lighter flywheel....even my buddy on his 450R noticed a big difference when he jumped on my shee... Quote
BigRed350x Posted January 9, 2006 Report Posted January 9, 2006 You say you are using these for trail riding i would definately suggest CPI pipes they have the best low to midrange power increase. If you plan to port these are definately the way to gol. They are better than toomys and cheaper the PT mids. 456670[/snapback] WHAT?!?! Dude, go away. CPI for low? ahahhahahaha Get real man. Quote
H250RHATER Posted January 9, 2006 Report Posted January 9, 2006 You say you are using these for trail riding i would definately suggest CPI pipes they have the best low to midrange power increase. If you plan to port these are definately the way to gol. They are better than toomys and cheaper the PT mids. 456670[/snapback] HA WHAT?!?! Dude, go away. CPI for low? ahahhahahaha Get real man. 456899[/snapback] right from some one who has them i know they are deff not a bottom end pipe the way your bike is ported can somewhat alter that but to say they have the best low to mid power increase dont make me laugh Quote
Shee-Male Posted January 9, 2006 Report Posted January 9, 2006 I love my FMF's for the trails they're just very peaky, my buddies Paul Turner hi revs are nice as well and roll on real smooth. Quote
Banchetta Posted January 9, 2006 Report Posted January 9, 2006 most of the riding i do is top end riding more than bottom end riding and i thinking of puting in big bore sleeves and pistons as well 456774[/snapback] So what do you not like about the pc pipes then if you like the high revs???? Quote
badxr6 Posted January 10, 2006 Author Report Posted January 10, 2006 So what do you not like about the pc pipes then if you like the high revs???? 457082[/snapback] just want to know if there is anything that could be better than what i have Quote
Banchetta Posted January 10, 2006 Report Posted January 10, 2006 just want to know if there is anything that could be better than what i have 457527[/snapback] Better could mean a 100 different things. If you want us to help, we need specifics...if you want more revs, more low end or are you just looking for more power?? Quote
MILO Posted January 11, 2006 Report Posted January 11, 2006 i've only had the stocker's and my pc's, but i can't complain about the pc's. i ride trails and open farm areas and they seem pretty good all around. the low end bog is pretty rare, mostly if you are really puttin around, but it's nothing that a little slip of the clutch won't fix. i like the look and sound of the pc's better than a lot of the others anyway, so i've never had a reason to try to switch yet. most guys recommended the pc's when i was asking about getting some for a fair mix of trails and open riding. most of the others seem to be a bottom end, or top end pipe, and pc's are a good mix of both. Quote
badxr6 Posted January 11, 2006 Author Report Posted January 11, 2006 Better could mean a 100 different things. If you want us to help, we need specifics...if you want more revs, more low end or are you just looking for more power?? 457753[/snapback] would the t5 be better than the pc pipes for more horse power bearing in mind i am putting in the 69mm pistons Quote
