bladesracing Posted December 2, 2005 Report Posted December 2, 2005 I want to start doing endurace desert races, but I've been told I need a 4 stroke anyone got any ideas of what I need to do to make my shee ready?? thanks Quote
RATBIKE0130 Posted December 2, 2005 Report Posted December 2, 2005 A big gas tank and suspension is pretty much it. If you ride at night you might want to look into a battery setup and some HID lights. There are a couple guys that race out in the desert and they will most likely chime in with more. Quote
warwgn Posted December 2, 2005 Report Posted December 2, 2005 same as above, but also add in longer swing arm, antivibe sterring stem, steering damper, and gear a little higher to help reduce the power band pull, your arms will thank you after about 30 miles. A good twist throttle is also a good idea if you can get used to it. Quote
chipdog Posted December 2, 2005 Report Posted December 2, 2005 (edited) no way. i got me a yfz450 and kept the banshee for drag racing.to much trouble now aday i put over 5 grand into the shee for desert racing and it still wasnt good enough. bought the yfz450 and all i needed was skids front to back and an exhaust system. but all in all if you got the dough then go with the flow.this was the final product.everything needed for a good desert racer. Edited December 2, 2005 by chipdog Quote
bladesracing Posted December 2, 2005 Author Report Posted December 2, 2005 thanks for the ideas. I just can't imagine life with any other quad than a banshee Quote
decon Posted December 2, 2005 Report Posted December 2, 2005 banshee's are perfect for desert racing, although it's weak side is suspension. I looking in your profile and see you've already got the engine mods so work on the suspension. not sure if you want a longer swingarm, you would get less traction, go shorter. definately a steering stabilizer, 5 gallon ims tank, whole new front suspension +2+1 a-arms with new shocks, rebuilt rear shock, skids, etc Quote
dawarriorman Posted December 3, 2005 Report Posted December 3, 2005 If im right, I do believe the Banshee has won Baja more than any other quad. Now granted there really wasn't any competition during all those years, but still. Quote
ogre03 Posted December 3, 2005 Report Posted December 3, 2005 (edited) I'm by no means an expert of any kind, but I think Upgrading your radiator would be a good idea. Someone tell me if I'm wrong, I don't want to suggest he spend his money somewhere that it's not really needed, but the cooling system is a weak point on the shee. Edited December 3, 2005 by ogre03 Quote
bladesracing Posted December 3, 2005 Author Report Posted December 3, 2005 Thanks for the ideas and making me feel better about racing a banshee!! Any suggestions on what brand suspensions?? How about swing ar upgrades, are they needed? Quote
decon Posted December 3, 2005 Report Posted December 3, 2005 (edited) Thanks for the ideas and making me feel better about racing a banshee!! Any suggestions on what brand suspensions?? How about swing ar upgrades, are they needed? 444392[/snapback] Well what's your budget for suspension? For swingarm upgrades you can have the stock swingarm cut shorter for more traction but that's if you want to. they arent needed but would benefit for more traction. what kind of paul turner pipes do you have (mids/ hi rev)? porting type? Edited December 3, 2005 by dEcon Quote
chipdog Posted December 3, 2005 Report Posted December 3, 2005 (edited) Thanks for the ideas and making me feel better about racing a banshee!! Edited December 3, 2005 by chipdog Quote
cutiegirlracing Posted December 3, 2005 Report Posted December 3, 2005 thanks for the ideas. I just can't imagine life with any other quad than a banshee 444218[/snapback] [/quot ) Tell me this man is single Quote
Wallrat Posted December 3, 2005 Report Posted December 3, 2005 (edited) Edited December 3, 2005 by Wallrat Quote
RNBRAD Posted December 3, 2005 Report Posted December 3, 2005 Or do a search on the Duncan Banshee in the Pont De Veu. It raced against the new 4 smokes. They said there was just no way they could match the top speed of the banshee in the straights. Quote
