hello, i am about to get the banshee up and running today.Ive went with a 2 into 1 carb setup and will be using 1 of the 2 mikuni 34mm flat slide carbs that originally came with my banshee.my problem is i know one of the 2 nipples on the carb had a rubber tube connected to the other carb but now that i don't have 2 carbs do i just plug it off?and theres another nipple on the opposite side of the carb, i don't think anything was hooked up to it.should i plug off that nipple or what do i do with them.also theres a gold maybe brass nipple on the bottom of the bowl.do i just leave it alone or what should i do?and what do these nipples do?i can blow air through all 3.
thank you
First thing I thought of when I saw the title of the thread was "pinch them".
Maybe put clothes pins on them.
Or alligator clips.
And then smack them off with a belt.
418729[/snapback]
great minds think alike huh stan??? :D
I don't know much about the 34mm Mikunis, but if they are anything like the stockers, the first two "nipples" do sound like choke crossovers. If that's the case and you don't block those off you will have a pretty big air leak going straight in. I'm assuming the carb you have mounted has some sort of choke pull, or do the 34mm not have that, just wondering if maybe you actually want the other carb installed on the bike if it has the choke pull, otherwise you wouldn't have any choke. The third nipple on the bowl is an overflow, route it out the back, the stock ones dump in between the case and the swinger.
thanks for the replys, both of the carbs have chokes on them.so do i just put tubes on them or block them off? i would think to block them off to be on the safe side and not risk an air leak and cause a lean condtion?but i have no clue.i looked on the mikuni website but didnt have any luck there.
thank you for your help
Just block them off. I just put some 35 mms on mine. One came blocked off, the other has some tubes on them. I blocked both of them off per Jeff at F.A.S.T.
why go with 1 34mm when you could have 2?  seems wierd to me.
418836[/snapback]
im trying to make it more trail friendly. maybe in the future ill try out the duals.but for now i want to run the single, if i can figure out what to do with these nipples.
418848[/snapback]
we posted at the same time but you were a little faster.im going to block them of by putting some hose on them then sticking an empty 22 shell in the other end to block it off unless these a better way?
thank you
do bigger carbs make a huge difference over stock? Which is a better setup for trails, a 2 into 1 or 2 bigger carbs like 34-35?
Just to give you a quick setup of my banshee i have t5s, noss head with 21" domes, +4 advanced timing, v-force3 reeds, pro flow and k&n filter and i just ordered a nology coil and wires today :D
I was just thinking of what my next mod should be. I only got my banshee a few months ago and I cant stop doing mods to it. Im addicted! :drool:
