wildbansheeboy Posted August 25, 2005 Report Posted August 25, 2005 What is the best gearing set up 4 300ft drags?Is it better to go low and start in a higher gear or is it better to go high my banshee has lots of mods but this gear thing is one thing I am still working on right now I have a 13 on front and 44 on rear and start in 2nd but I think I can get better times if I play with my gears .Any Ideas? Quote
Mod Banshee Posted August 25, 2005 Report Posted August 25, 2005 I drag race in 300ft I am am running 15/41 gearing and It has been working for me for two years Quote
fast87 Posted August 26, 2005 Report Posted August 26, 2005 i run 14/43 and it works great for me, in the 300ft i barely hit 5th gear, and have a good launch in 2nd...unfortnately i'm getting beat by too many people...time for upgrades!! and a job!! ~Mark~ Quote
locogato11283 Posted August 26, 2005 Report Posted August 26, 2005 i would try gearing up some. i run 15/44 on my 4mm setup for hillclimbs but on a flat drag race i know i can pull a lot more gear than that... Quote
fastbanshee4u Posted August 26, 2005 Report Posted August 26, 2005 We need your tire size to help.Also what are your mods.You are geared to low unless you have bigger tires. Quote
wildbansheeboy Posted August 29, 2005 Author Report Posted August 29, 2005 The tires I use are paddles 22x10x9 Quote
FASTOYS Posted August 29, 2005 Report Posted August 29, 2005 gearing has alot to do with rider wieght, how strong of a motor (stroker, stock, play port , race port, etc.), how many paddles or size tire, How light of bike (drag or stock frame), how long of swingarm, and what your runnin on for a track! Your current gear sounds pretty low to me. Unless you wiegh 400 lbs and run 12 paddle taller haulers with stock swingarm! Quote
wildbansheeboy Posted August 30, 2005 Author Report Posted August 30, 2005 I RUN A 8 BLADE PADDLE SIZE 22X11X9 IN SAND AND 20 INCH HOLE SHOTS ON DIRT/GRASS MY MODS ARE 35MM KEIHIN AIR STRYKERS WITH OPEN K&N FILTERS,20CC DOMES IN A COOLHEAD,STAGE6 PORTING DONE BY A&S,30. OVER WISECO PRO LITE PISTONS,BOOSTBOOTLE,3/8 INCH REED SPACERS, RAD VALVE REED CAGES ,1000RPM OVER STOCK CDI BOX,PRO CIRCUIT PIPES AND A TIMING PLATE ON THE WAY. THE SHEE HAS BEEN LOWERED 3' AND AND RACE CUT FENDERS THE REST IS STOCK .THANKS TO ALL WHO HELP Quote
