Mod Banshee
Everything posted by Mod Banshee
  1. My plugs are way black. Now the plugs that was in it befor I put the 35mm carbs on are a nice chocolate color.
  2. I dont know what elevation we are at I live in NY if that helps. I am running Klotz oil and super gas (93) and I am mixing it 32-1. I am doing the proper plug chop. It is backfiring and poping. But first gear is fine
  3. Ok I had 170 Mains and clip in second grove. Plug came out black. So I went with 150 mains and moved the Slip to the middle grove andthey are still black.
  4. Hey they are my carbs. If u want them I will end it and let u have them for $125 + shipping. I also have the same ones in a 34mm I will be getting ready to list.
  5. I will be going to Jeff when I am ready to order.
  6. Yes it is
  7. I am go to be getting a 68mm Cheetah Cub with a 4mm Crank and I am going to have Jeff from fast racing do a clean up port Job on it, And he gave me a price of $1600
  8. he told me the only way he would do a full port is if I was going to use a +10 or +12 swingarm and if I was going to run monster carbs. But RDZ will do a drag Port and it will only be $50 more then jeff
  9. I just got off the phone with jeff from Fast racing. And he gave me a price of $1600 for the Cheetah Cub Cylinder kit and a 4mm Crank and his clean up port job. And will 35mm PWK carbs work on this set up?
  10. I called Vitos and they talked me in to getting the Cheetah Cub Cylinder kit. It is 68mm Cylinder and a 4mm Crank. So I will get the hole kit for $1706.90
  11. Ok I was thinking about it and I am going to get the Passion 12 port Stroker kit. But should I get the Full drag Port?
  12. I dont ride alot of trails with my shee. So I would say it is going to be my drag bike. My tail bike is my 05 Outlander 800.
  13. I am going to be getting a new Crank for my shee but I dont know if I should get the 4mm or the 10mm. I trail ride and drag race my shee.
  14. Put my name in too
  15. I am going to be rejetting my banshee for my new carbs My carbs are PWK 35 mm with my Mod were do you thank I should start at?
  16. I have20x11x9 Razr 2 with every other row cut out. And he has a set of 22x11x9 Duro HF-243. And before the R he had a stock Blaster
  17. He got the big bore from my Cousin and he told me that it is set up for Motor cross. And they are going to use it for drag racing. The kid that is going to race it is 14 and about 125-130lbs
  18. look at my signature for my Mods. He has LRD 300 big bore LRD head with 25cc on race gas LRD Pipe and silencer Keihin 38mm Air stryker carb V-force 3 K&N air filter Hot rod crank The Race will be 300ft on dirt
  19. Ok thanks
  20. I have the boss intake and my boots that are on it are for 34mm carbs but will 35mm carbs fit ?
  21. with my Mod were should my jetting be at?
  22. I would get that shee Ported
  23. I got race logic stage 2 porting. Race Logic call it superstock porting
  24. I can not say I have never tested and set of CPIs or a set of shearers. But I did line up with a banshee with a set of Shearers and it was a good race. I came out on top it was a 300ft drag race.
  25. I have a set of rocket pipes on my Banshee and I love them. They pull like hell from low end to top end. And the Fit and Finish is real good on them and the also sound way cool.
