hittintrees srh Posted August 6, 2005 Report Share Posted August 6, 2005 (edited) Ive got an 01' bansh with quite a few mods (check out my sig.). With my set-up, you'ed think my quad is hella fast, but I lost to a mostly stock 05' bansh(I think he only had CPI's, pods, and gears). What the hell It starts and runs pretty damn well-even at w.o.t.- though I do feel some hesitation-but not much at all. When I was draggin, I started in 4th and dumped the clutch while pinned- and it launches freakin hard, then when i shift, it boggs out bad. I have 19cc domes in it,and making 130psi. Should i go to 18's?? Im thinkin I mite because im gettin so much fuel from my Lectrons. What do you guys think???? BHQ RULES P.S. Im not sure what kind of porting I have. Is there any way to find out just my measuring the intake ports? Edited August 6, 2005 by hittintrees srh Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted August 6, 2005 Report Share Posted August 6, 2005 compression sounds low. How much time on your current top end? Probably time to do the cylinders. Match the pistons to your port work while your at it. Quote Link to comment Share on other sites More sharing options...
sredish Posted August 6, 2005 Report Share Posted August 6, 2005 If your starting in 4th, it sounds like your geared too low. what's your gearing currently. You want it to where 2nd is a little tall but just enough to get a good start. Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted August 7, 2005 Author Report Share Posted August 7, 2005 If your starting in 4th, it sounds like your geared too low. what's your gearing currently. You want it to where 2nd is a little tall but just enough to get a good start. 401621[/snapback] I still have stock gears front/rear. And is 130psi low?? if it was'nt for my port i'd be around 150. The top-end looked fine when I had the head off. Could it be a reed problem? Eather way, Im tearin that f**ker down this weekend- It'll be fast-It had BETTER BE FAST!!!!!!!!! Thanx for the help so far- keep the suggestions coming please. Quote Link to comment Share on other sites More sharing options...
23champ Posted August 7, 2005 Report Share Posted August 7, 2005 Why are you taking off in 4th gear? Are you racing on snow, or down a mountain side? If you have enough power to take off in 4th gear with stock gearing, you shouldn't have any trouble winning a race. Quote Link to comment Share on other sites More sharing options...
cjm02ram Posted August 7, 2005 Report Share Posted August 7, 2005 Sounds like the rider is the problem...Why would you take off in fourth gear???? With your mods I would say you should beat a stock bike but you wont be all that fast against any modded banshees. LOL, 4th gear Quote Link to comment Share on other sites More sharing options...
trex banshee Posted August 7, 2005 Report Share Posted August 7, 2005 4th gear takeoffs with stock gearing. i don't see any possible way. if you can do that what does it do when you take off in first or second. By the sounds of it it should blow the tires up with all your power. Quote Link to comment Share on other sites More sharing options...
bansheeryder_69 Posted August 7, 2005 Report Share Posted August 7, 2005 4th gear? WTF? you obviously need to change your gearing if you can do that. If you keep doing that too your going to probably need a new clutch.Try adjusting your gearing before you do anything. Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted August 8, 2005 Author Report Share Posted August 8, 2005 Well starting in fourth was a wrong idea on stock gears, But the problem still remains. It boggs really bad. Well I tore it down, I looked at the reeds, and the left side looks wierd. Are the reeds supposed to sit flush against the cage? My left side reeds sit up about a millimeter. Ivew never seen a bad set so im not sure if thats bad or not. Could use some help here. Thanx dudes. Quote Link to comment Share on other sites More sharing options...
lincster Posted August 8, 2005 Report Share Posted August 8, 2005 130psi on 19cc domes, you need to do a top end rebuild. I have 155psi on 20cc domes. 4th gear starts, no way, rider error. You should be starting in 2nd when dragging. With a piped bike a 20cc domes, no way will the bike lose to a stock bike. sorry dude, but it is the rider. Quote Link to comment Share on other sites More sharing options...
Dunsmoor86 Posted August 8, 2005 Report Share Posted August 8, 2005 Yeah I run 20cc at 800ft above sea level with more than a mild port and I run 156-160psi. Top end=need new one Quote Link to comment Share on other sites More sharing options...
pimpeinkc Posted August 8, 2005 Report Share Posted August 8, 2005 130psi on 19cc domes, you need to do a top end rebuild.I have 155psi on 20cc domes. 4th gear starts, no way, rider error. You should be starting in 2nd when dragging. With a piped bike a 20cc domes, no way will the bike lose to a stock bike. sorry dude, but it is the rider. 402296[/snapback] no shit, i have 21cc domes and i have higher compression then that. get some rings or something, then start in 1st or 2nd, have you been running high octain gas with those domes, anything under 20cc needs higher octain, might have burnt the rings some..... good luck, and let us know if it fixes your problem, till then i want to race..lol Quote Link to comment Share on other sites More sharing options...
trex banshee Posted August 8, 2005 Report Share Posted August 8, 2005 Well starting in fourth was a wrong idea on stock gears, But the problem still remains. It boggs really bad. it is going to bogg really bad if you try taking off in fourth gear. did you even try to take off in first or second before you took it apart? Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted August 8, 2005 Author Report Share Posted August 8, 2005 (edited) Yeah I run 20cc at 800ft above sea level with more than a mild port and I run 156-160psi. Top end=need new one Edited August 8, 2005 by hittintrees srh Quote Link to comment Share on other sites More sharing options...
odaen Posted August 8, 2005 Report Share Posted August 8, 2005 compression guages differ substantially in their readings. i wouldn't get too hung up until i compared it against another bike. but 4th gear starts? c'mon, man, not unless you're running R/C tires on your shee Quote Link to comment Share on other sites More sharing options...
