My buddy gave me a brand new tether switch from pro design, with no instructions. How hard could it be? Two wires, I thought easy. Well as it turns out, the thing just dont work. The banshee starts just fine but when I pull the chord, it stays running, any info would be greatly appreciated! Thanks
I wired it in through the Ignition switch like he said too. If hes wrong Im gonna kick his A** for making me cut my wire harness.!!!
typically the way to wire them is one wire to the pos side of the coil, should be orange I think, then the other wire to a good ground.
I bought one of these too and it worked about 3 times now same thing it doesn't do anything at all if you figure it out let me know thanks Tim
i got a tusk one
take your light and kill switch off your handlebars get the wires outta the kill switch and hook the 2 on the tether switch up to those
that should do it
but im not sure about the pro design ones i heard they hook to the orange wire too
worth a shot though you can always put the wires back in your kill switch
I have mine wired in repacement of the stock on-off switch, never been a problem
393581[/snapback]
This is exactly how i wired my sons shee and have not had any probs since.try it like
dirtplay says. :)
393602[/snapback]
this has happened to my pro design as well, what happens is it gets wet and all the other crud in there from riding and it gets a little corroded, then thing to do is simply take it apart and clean it then lube it up and itll work fine. there is a small set screw on the backside where the handlebars go that holds it together. hopefully that will fox your prob
if you wired it into the ignition swith..as in key switch they thats your problem. You have to run it into either the white/black wire from the kill switch of the orange coil wire
  • 2 months later...
Install inst are as follows for a banshee.short wire goes to ground and longer wire of the two goes to orange wire on coil. If you are still using your factory key switch you must disconnect it for the pro-design kill switch to operate right.
I still have my key switch just found dirty wires and had to clean, cut back and reconnect it works purrfect now. brapp brapp
on my 250r, i just got rid of the factory kill switch/light switch. i also took all the lighting wiring out though. ive got the pro design, had it on my warrior. now, ive just got to figure out where i messed up on the wiring:shootself: got it runing again the other day, pull the cord, still running. had to do the old front brake/clutch pop trick. now just got to run wires AGAIN!
