JohnnyWadd Posted May 15, 2005 Report Posted May 15, 2005 Woo hoo, my first post. Anyway, today I just picked up an 87 banshee. I got a great deal on it too. I have big plans for this bike. I just sold my 96 kawi ninja and had to get another toy . Alright, say you have $1500, what would you do? I am already planing on powdercoating the frame black, and getting black plastics. What engine mods would be the best for the money? Quote
flanders Posted May 15, 2005 Report Posted May 15, 2005 (edited) what kind of riding are you wanting to do? for $1500, you should get: toomey t-5's or rockets (around $600) mild port job (around $350) noss cool head ($250) K&N filter pods (i think theyre around $70 for both) v-force reeds ($250) edit - you could also probably pick up a pair of used pipes for much much cheaper, and use that money for powder coating the frame or you could use it to get some 28mm carbs for like $300. also, the first thing i would change is the thumb throttle to a twist. Edited May 15, 2005 by flanders Quote
JohnnyWadd Posted May 15, 2005 Author Report Posted May 15, 2005 It will be a dune machine only. No trails. Also, do you think I will need to get my crank welded? I was thinkin about runnin' either 19cc or 20cc domes on the cool head. That would put me around, what, 150PSI? Quote
flanders Posted May 15, 2005 Report Posted May 15, 2005 It will be a dune machine only. No trails. Also, do you think I will need to get my crank welded? I was thinkin about runnin' either 19cc or 20cc domes on the cool head. That would put me around, what, 150PSI? 369398[/snapback] i would get ur crank welded. bein ported and runnin 19's would put you pretty close to 150. if ur doin dunes only, you should get the swinger extended +4. Quote
Banshee17Racing Posted May 15, 2005 Report Posted May 15, 2005 well, it looks like you've already got some type of Toomey's, flanders list sounds pretty good, i'd really look into welding your cranks with 19cc. By the way, you should be over 150 psi w/19's, i've got 21's and i'm at 155 psi.(700 ft. elevation) Quote
locogato11283 Posted May 15, 2005 Report Posted May 15, 2005 i would go with some rockets, a dune port, noss head, good intake, bigger carbs and get that crank welded... Quote
decon Posted May 15, 2005 Report Posted May 15, 2005 nice deal. by the look of those silencers, they are some old toomeys. u mind posting more pics of them (i.e. side, back angle) ? and for 1500 u can get alot. i would get some new pipes, dune port, nosshead, carbs, pro flow air filter. maybe you could even fit some suspension in with that money if u find some good deals. as for pipes their are alot of good pipes for the dunes. rockets, toomeys, shearers, cpi's, etc, just depends on what type of power curve u want. also, i would worry about the engine first before the looks. Quote
sheecandy Posted May 15, 2005 Report Posted May 15, 2005 first i would redo the bottom end new crank and seals if you have a shop do the work ask about a package deal rebuilding your bottom end and some dune porting while you got your motor out have your frame powdercoated if your pipes are in good shape i would just clean them up and repaint them make sure you rejet for all your new mods oh yea dont forget some skat trak paddles on douglas blue lables have fun Quote
sp1tekiller Posted May 15, 2005 Report Posted May 15, 2005 Nice tires out back. Those Spider Tracs are sick in the mud. Quote
03LE Posted May 17, 2005 Report Posted May 17, 2005 I say project sleeper that SOB, get some black pipes, Vforce 2 reeds and all the other stuff, (listed above) maybe cut the front fenders and go out and smoke people with it. Quote
ellison445 Posted May 18, 2005 Report Posted May 18, 2005 Hit Nyuk up, He got you covered on bars,pipes and nerf bars...You wont find a better deal!! Quote
