jury Posted May 11, 2005 Report Posted May 11, 2005 i just had my heads cleaned up,put in new rings and put it all back togeather with all new gaskets, and the lower front of the cylinder is leaking water and it barley runs, should i just take it apart and throw some gasket maker in there? Quote
BigRed350x Posted May 11, 2005 Report Posted May 11, 2005 i just had my heads cleaned up,put in new rings and put it all back togeather with all new gaskets, and the lower front of the cylinder is leaking water and it barley runs, should i just take it apart and throw some gasket maker in there? 367938[/snapback] I would just buy some new gaskets & rings and be on the safe side. Quote
jury Posted May 11, 2005 Author Report Posted May 11, 2005 the rings are new it ran for about 30 secounds... Quote
locogato11283 Posted May 11, 2005 Report Posted May 11, 2005 sounds like you need to pull the rubber plugs out of the cylinders, clean them up and use some yamabond to seal them back up. if its leaking from the bottom of your cylinder in the front thats the problem. your prolly suckin coolant making it run like shit. pull the cylinders and check those plugs. Quote
98bonerSTOCKshee Posted May 11, 2005 Report Posted May 11, 2005 i just had my heads cleaned up,put in new rings and put it all back togeather with all new gaskets, and the lower front of the cylinder is leaking water and it barley runs, should i just take it apart and throw some gasket maker in there? 367938[/snapback] lower front of the cylinder? Make sure you tightend the bolts in the correct sequence and proper torque, if still leaking it prob. needs a new base gasket.. Not a good idea to use sealer it possiblly could get sucked into the motor where it's not needed... Quote
superchicken Posted May 11, 2005 Report Posted May 11, 2005 like loco said check the rubber plugs.it shouldnt need any silicone to make it run Quote
jury Posted May 11, 2005 Author Report Posted May 11, 2005 dam alright is yamabond the same as some permatax, whats the pattern for the cylinders, and its 20 lbs right? im new at the banshee stuff ha but im learnin Quote
locogato11283 Posted May 11, 2005 Report Posted May 11, 2005 any high temp silicone will work. pull the plugs out. clean up the edges of the cylinders where those plugs go in. put a bead of silicone around there and put the plugs in. wipe off the excess. let that shit set up before you start your banshee up. usually takes over night. the reason its running like shit is because your sucking coolant into the cylinder. i bet your radiator level dropped a little didnt it? Quote
98bonerSTOCKshee Posted May 11, 2005 Report Posted May 11, 2005 dam alright is yamabond the same as some permatax, whats the pattern for the cylinders, and its 20 lbs right? im new at the banshee stuff ha but im learnin 367980[/snapback] your lucky I gots the good ole clymer right here.. 20 lbs for cylinder and head bolts.... cylinder base uses a criss cross pattern per cylinder. . Here's a pic I did for ya for the head pattern.... ps don't laugh at my art skillz... Quote
jury Posted May 11, 2005 Author Report Posted May 11, 2005 sweet thanks alot i ordered a clymer dont have it yet, but no i didnt check the rad. level, i checked the plugs on the bottem of the cylinders they look alright heres a picture.... do they pop out or do i just yank them out Quote
jury Posted May 11, 2005 Author Report Posted May 11, 2005 well thats one of them otehr ones pretty much the same so they look bad or can you not tell Quote
locogato11283 Posted May 12, 2005 Report Posted May 12, 2005 if you have your cylinders off pour some water down into the water jackets and see if it comes out where those plugs are. if it does then pull them out and re-silicone them. if not you have a problem somewhere else. Quote
fastbanshee4u Posted May 12, 2005 Report Posted May 12, 2005 Your gaskets should cover up the rubber plug so it dont leak.make sure the bottom of your cylinder is flat and nobody has marred it up trying to get it off.You could have a high spot not letting the entire surface seal .There is a spray gasket sealer that might help you its not thick like silicones. Quote
locogato11283 Posted May 12, 2005 Report Posted May 12, 2005 Your gaskets should cover up the rubber plug so it dont leak.make sure the bottom of your cylinder is flat and nobody has marred it up trying to get it off.You could have a high spot not letting the entire surface seal .There is a spray gasket sealer that might help you its not thick like silicones. 368205[/snapback] you shouldnt depend on the gasket to keep water from gettin in there. those plugs should be siliconed in to ensure they dont leak. Quote
jury Posted May 12, 2005 Author Report Posted May 12, 2005 alright thanks alot, i took them out and sealed them up so im letting it sit over night hopefully this is the last time i have to take it apart for a while, third times a charm Quote
