bansheexj Posted April 10, 2005 Report Posted April 10, 2005 which head should i run everyone is talking about the noss head but whats the diff between it and trinity's head? i know that pro designs is no good but what is honestly the best bang for your buck? Quote
cOoLDeviL Posted April 10, 2005 Report Posted April 10, 2005 trinity head is the best but its more expensive than noss it force the water to cycle in the head and move it down to cool the jugs Quote
rocketboy Posted April 10, 2005 Report Posted April 10, 2005 if you want the best bang for your buck look in the image section at "my cnc cut rechambered head" itll pump out out serious compression and cheap$$$$ ,and is taylor made for your machine ,but if you insisit on a coolhead, get a noss head .theyre the best Quote
05bansh Posted April 10, 2005 Report Posted April 10, 2005 The best head is any head I can get I mean.....I would buy the noss head over any other head out there. Quote
RNBRAD Posted April 10, 2005 Report Posted April 10, 2005 trinity head is the best but its more expensive than noss it force the water to cycle in the head and move it down to cool the jugs 352683[/snapback] I believe the noss head does the same thing. The pro-design unit does not. It can be corrected though with a set of trinity domes and possibly noss domes. Quote
RBD Posted April 10, 2005 Report Posted April 10, 2005 if you want the best bang for your buck look in the image section at "my cnc cut rechambered head" itll pump out out serious compression and cheap$$$$ ,and is taylor made for your machine ,but if you insisit on a coolhead, get a noss head .theyre the best 352704[/snapback] rocketboy, How did that head work out? Tell us all about it. Quote
rocketboy Posted April 10, 2005 Report Posted April 10, 2005 well i havent bolted it up yet ,but its gonna be sweet .18.6cc and pumps out 220 psi on stock porting @sea level and should hit 160lbs with my port setup and elevation .ill let you know soon looks to be ver yprofessioanlly done ,sad part is im a tool and die maker, i should have done it myself ,im a lazy bastard too though Quote
locogato11283 Posted April 10, 2005 Report Posted April 10, 2005 i would go with noss head. excellent customer service and good looking product.. Quote
racer Posted April 10, 2005 Report Posted April 10, 2005 im gettin an RK-Tek for my next go around. Quote
mxbanshee Posted April 10, 2005 Report Posted April 10, 2005 (edited) Click here: TRINITY IS BY FAR THE BETTER HEAD Edited April 10, 2005 by mxbanshee Quote
rocketboy Posted April 11, 2005 Report Posted April 11, 2005 the noss head is much cheaper and you have the sure flow cooling design with his and your head studs will not need changed and theyre available in different anodized colors and if go NOSS , the best part is trinity racing wont get your hard earned money, cause you know theyre just gonna use it to pay there 6$ an hour engine porters Quote
dlnoss Posted April 11, 2005 Report Posted April 11, 2005 I don't usually give a sales pitch on my heads but some of the advantages are: Uses stock studs. Uses domes that are available from more than just the head manufacturer. Has improved flow and cooling characteristics over stock and many other aftermarket heads. Less expensive than many other heads although, from a quality standpoint, they really shouldn't be. Quick delivery. I am flattered that many top notch builders use my heads. Many Cub dealers and builders are selling them packaged with the Cubs. You DO have to consider that my opinion is biased. (but accurate) Quote
applpro Posted April 11, 2005 Report Posted April 11, 2005 I don't usually give a sales pitch on my heads but some of the advantages are: Uses stock studs. Uses domes that are available from more than just the head manufacturer. Has improved flow and cooling characteristics over stock and many other aftermarket heads. Less expensive than many other heads although, from a quality standpoint, they really shouldn't be. Quick delivery. I am flattered that many top notch builders use my heads. Many Cub dealers and builders are selling them packaged with the Cubs. You DO have to consider that my opinion is biased. (but accurate) 353076[/snapback] Your customer service can't be beat-very nice people to deal with. Super fast shipping & a high quality product to boot! I'm very happy with my purchase. Quote
sno_pro27 Posted April 11, 2005 Report Posted April 11, 2005 I AGREE, THE PRODUCT, THE SERVICE, IS SECOND TO NO ONE installed my head, HOLY SHIT, it came alive!!! Quote
