cOoLDeviL
Everything posted by cOoLDeviL
  1. 2003LimitedBanshee i have the same problem that you have. when i finish from WOT riding i can see a small amount of smoke out the 2 silencers and they are hot . so whats the couse of this problem and did you solve it ?
  2. so if i add the reed spacer between the carb boot and the reed will i still have the same low end power with much better top end . or i will lose some of the low end power to gain the top end ?
  3. i know that the reed spacer is waste of money on dual carbs and no power gains in no wear . but the single carb have more low end power with less power on top so can i fix this problem by adding reed spacer between the carb boot and the reeds to add more length to the track to help the top end revs ?
  4. my banshee is moded right now i have trinity head with 21cc dome and single carb 35mm advanced timing +3 and GYT-R CDI clean up port job lighted flywheel ported reed cages with power reeds . i tryed the LRD pipe and adjust it to the low power and the top end is much better than the FMF SST .
  5. whats the difrance between theas 3 pipes in power 1- FMF-SST 2-LRD adjustuble 3- PRO-circut for banshee right now i have the FMF-SST on my banshee but i want more power.
  6. ho much for the Dynaport polished 2into1 exhaust ? and is thear any pic of them ?
  7. trinity head is the best but its more expensive than noss it force the water to cycle in the head and move it down to cool the jugs
  8. thank you all for your help and i finally made up my mind to stik with the SST
  9. hi all and what is the diffrance between theas 2 set of pipes i mean in power ? i have right now the FMF-SST pipe on my banshee but im thinking of changing it. dont get me wrong but i want somthing that has more low end power with out lossing to much in top end . i know thw 2 into 1 pipe by Dynoport is great in low power but it kills my top end and FMF Gnarly's also has the same result but i dont have any idea on the PTR mid's how they compaire to FMF-SST i heard that PTR mid's are exelant in low power with good top end but if i switch from SST to PTR mid's where should i feel the diffrance in power and is thear any top end loss or what ?
  10. so after compairing theas 2 set of pipe with each other and reading your openion i should stick with the SST pipe . thanks all for your help
  11. hi all and i would like to know what would be the difrance in power compaire to each other ? right know i have the fmf-SST and im thinking to change it to dynoport 2into1 pipe . my setup right know is fmf-sst with trinity head with 21cc doom , +4 advance timing , 64.25 stock pistons non-ported engine , trinity 35mm CV single carb , boyseen power reeds with ported stock cages and GYT-R ignition . so is the dynoport work with this setup or not and if it work what would be the result in power .
  12. i cheked them but thear is no leak .
  13. i know that sredish thats why i order the EEK needle and it should be here in the end of the week with some main jet size .
  14. hi Wallynut mine came with DGK needle and when i move the clip to last clip 5th with 225 main it workes better but still not dial right it needes more fuel on top i will try 235 main and see what will happen
  15. hi KRMit how are you . which needle do you have in your carb is it DEK or DGK ?
  16. ok thanks for all of you how help me out
  17. im at sea level with temp around 50 ~ 90 and my setup now is 45 pilot with the needle in the 5th clip from top thats the last clip down with 195 main . before was clip 4 with 45 pilot and 195 main . but now its beter with the 5th clip but still problem in the main section
  18. the dgk is a long needle with to much taper. what do you mean in that is it recher or leaner than the DEK ? i know that the EEK is richer than the DEK but i have no idea about the DGK ?
  19. i have problem in my main jet i can't get it dial right i tryed every set that i have and stell didn't get it . i tryed 175 , 185 , 195 , 225 , and all theas jet's with no diffrance . the problem that i have is the half throutle has more top end than the WOT does any of you know what couse this problem ? im realy sik tired because of this ? any info will help .
  20. hi all i have the trinity C.V. system with 35mm and yesterday i opend the needle to see that what i have inside is not DEK or EEK it was DGK what that suppost to mean and this needle is it good or bad ?
  21. hi all and can some one help me out on this . which porting has more acceleration and good top end ? and for the powerband which one come's faster ? my riding style is draging some friends cruising on the street and sands and my setup is 35mm single carb FMF SST pipe timing plate and stock gearing .
  22. ok sredish what kind of port job you want to use ? and which pistons ? and for the EEK needle what is the part number for it ?
  23. hi all and i want to ask which head is better in cooling and long lasting and performance and which one use the stock studs im loking in trinity stage IV or the NOSS red one with 21cc dome .
  24. ok sredish you say that i should drop the main jet to 200 but i only have 195 is it ok. and for the needle do i have to drop it to the last clip down with 195 main . but when i ride it it has a good response all the way up .
  25. hi all i have a problem in my banshee at WOT it cut off so fast in 6th gear like it stop from rev. more than that and in this case when i back the throtle bach to 3\4 or less it start to move faster than full throtle and i see the speed meter start to move forward and feel the banshee pulling up " trail tech computer " and my setup is : 45 pilot 4th clip needle from top 225 main jet with direct mount k&n and im at sea level and now it idle fine but only start cold with choke and when its hot it start ok . stock engine with yamaha pistons 64.25 no porting. 1- FMF SST pipe. 2- milled head with 145 psi . 3- trinity 35mm single carb . 4- ported reed cages with power reeds . 5- timing plate with +3 . 6- stock gearing 14\41 . 7- GYT-R CDI . soon lighted flywheel in the way
