Here links to dyno's with Rockets dyno(Locogato11283 click) and (stclark816 click)
Looks like Loco get max power at 8800 and signs off at around 10k, stclark gets max power at about 9k and signs off a little before 10K. Where it signs off is somewhat subjest to interpretation, I looked at it as the point were they dropped off 10 Hp from the point where they made max HP. Rockets dont seem to just hit a wall where they completely quit, they have pretty good over-rev.
I have some differnt porting, tripple exhaust port, and dont make near as much HP as the clark boys but if I recall mine made max HP closer to 10k and signed off at almost 11k. mine had a big dip between 10 and 11 where the pipes almost seemed to come back on but not as much as when it was at max. I dont have the sheet siting right in front of me but I remember the dyno owner was supprised it reved so high. I have stock ignition with a +6 advance on the timing plate. I think a dyna or similar ignition would make a huge difference on mine and maybe get rid of the cammel hump at the top of the curve.
Also consider my and locos motor are +4mm stroke, I think stclark may be as well. Rockets might make max HP at a slightly higher rpm on a 350 motor.
my engine actually revs out to about 11,500. revs are gonna depend on more than just pipes. porting and other factors are involved. if you want rockets they will def out rev stock pipes. porting and carbs are a big determinant on gearing as well as pipes..
What is the top end rpms on the rocket pipes? And what would be good gearing to run with these pipes I drag race 300ft and Tirl ride. Now I have 15/41 I was going to try 15/38 or 13/38
347225[/snapback]
Tires are part of your gearing also, what size are you running 18-20-22 ?
ok my mods are
Rocket Pipes
Cool Head wirh 20cc domes
Bored 20 over
Wiseco Pro Lite pistons
Race Logic Superstock Porting
28mm Flat Side Carbs
V-Force Delta 2s
Boost Bottle
Team Alba Clutch kit
Hunson Clutch Basket
Hinson Cushions
Hinson Pressure Plate
Lightened Flywheel
Vitos Degree key
Pro Flow Intake
6 Filtered air vents
20x11x9 Razr 2s
ok my mods are
Rocket Pipes
Bored 20 over
V-Force Delta 2s
Boost Bottle
Hinson Cushions
Lightened Flywheel
Vitos Degree key
Pro Flow Intake
20x11x9 Razr 2s
348458[/snapback]
sounds like your running your airbox w/lid,those pipes will pull more air than your airbox can flow. yours probably won't rev as high. less air=less fuel=less power=less rpm. just my opinon
:bolt:
