it wouldnt hurt nor help you. youd just be spending about twice as much.
342940[/snapback]
I disagree- I think you would notice a bit snappier throttle, and it would run a little better.
343201[/snapback]
i disagree with you. i think it would be a waste of money. bump up the compression then run race fuel and youll notice a difference.
343204[/snapback]
Werd' Throw some 19cc domes in there and then you'll be good to go on the race gas.
I DONT THINK THERE WILL BE ANY BENIFIT TO RUNNING STRAGIT RACE GAS YOU DONT HAVE THE COMPRESSION TO NISESITATE IT BUT A MIX PROABLY WOULD NOT HURT YOU ADVANCE YOUR TIMING TO INCREASE THE BURN TIME OF YOUR FUEL THE LONGER BURN TIME GENERATERS MORE POWER
343266[/snapback]
'nother good point. 19's would make for a tire smokin bottom end also.
