BayBanshee Posted March 3, 2005 Author Report Posted March 3, 2005 Thanks for the picture RBD. My carbs do not have that Brass piece sticking out like that. Mine sticks up like that, but is is just a solid piece of aluminum. What is that brass piece for anyway? Did I get ripped off when I bought these? Rocketboy, I was thinking the same thing about that whole shop. I think they are all raging crack heads. So it sounds like I need to check for any air leaks and then try and get this thing jetted right. My brother talked to a guy and he said if I switched out my stock CDI box with a yamaha racing ignition, that I would not believe the difference it makes with 28 pwk's? Quote
RBD Posted March 3, 2005 Report Posted March 3, 2005 Thanks for the picture RBD. My carbs do not have that Brass piece sticking out like that. Mine sticks up like that, but is is just a solid piece of aluminum. What is that brass piece for anyway? Did I get ripped off when I bought these? Sounds like your carbs are PWK look a likes (not the Keihin ones), the brass tube on the Keihin carb is for bikes that use auto lube or vacuum petcocks. The Keihin carbs are made to work on many different makes and models of engines. No, you didn't get ripped off. The carbs you got just aren't drilled for the auto lube or vacuum operated petcock. Ron Quote
RBD Posted March 3, 2005 Report Posted March 3, 2005 Ps. Did your carbs fit the manifolds snuggly? Ron Quote
BayBanshee Posted March 4, 2005 Author Report Posted March 4, 2005 Thanks RBD. I am almost positive my carbs say Keihin on the side, but I will have to double check. My carbs fit a little loose, but I think I have them on pretty good. Quote
hamuel Posted March 4, 2005 Report Posted March 4, 2005 I had to get a real hose clamp because it wouldn't tighten down enough. after that they fight fine Quote
SuperChris Posted March 6, 2005 Report Posted March 6, 2005 Sorry I haven't got a picture up here for you, I will have another chance to go home this weekend(wednesday), I'll try then. Quote
