SuperChris
Everything posted by SuperChris
I'm running .1 over right now with no problems whatsoever. I did have to recut my domes.
New 28mm pwk - runs worse than stock carbs
SuperChris replied to BayBanshee's topic in Banshee Repairs and Mods
Sorry I haven't got a picture up here for you, I will have another chance to go home this weekend(wednesday), I'll try then. -
Shit dude, I'm sorry for not being more clear about it. Take the carbs off. I use stock boots. You don't need aftermarket boots until you get into much bigger carbs. Keep the crossover tube or boost bottle on. There is a chance I'll get to take a picture maybee tomorrow. I have to drive 200 miles to get to my Banshee and tester, but it would be a good excuse to go home for a couple days. -
Yep, I broke my Scaphoid a few years back on an IT400 I had just rebuilt. Long story, came back after riding by my myself with my shirt torn almost off, and grass sticking out of the exhaust pipe. The guys all laphed at me untill one of them noticed my wrist swelling up. He talked me into going to the doctor because he broke his scaphoid, let it sit for 2 weeks before going in and now he can't use it. I drove into urgent care and ended up in a cast for SIX months. When they say that is a slow healer, they aren't joking.
Is that really you?
Here's my recipe. Get one of those blood pressure checker kits from Bi-Mart or wherever(If you have a medical supply place near you just get the bulb and some surgical tubing). Get couple of rubber soft plugs from the local hardware shop(ask for them, they will know what you are talking about) and a 0-15 psi guage. You will need 2 soft plugs for the intakes, and 2 for the exhaust. Get a fitting that will allow you to make a T out of your surgical tubing, and get a fitting that will allow you to attatch one end of the tubing to your new guage. Take the ceramic off of one of your old spark plugs and stretch a piece of surgical tubing around it with the other end attatched to the bulb at a good distance(foot and a half is what I used). Put all your soft plugs in and screw a good spark plug in one side and your makeshift pressure checker in the other side. Find a good place to cut the tubing now and put in your T and guage. That's it. Pump it up untill the guage reads 6 psi and see if it holds. If not, spray soapy water around all the gasket areas and wherever it bubbles it is leaking. I have checked a lot of good running motors and every one of them so far has had leaks. -
3/8 by 4 inch extension and my 10MM socket work great to puch the pin right out. If it's stuck, there is something wrong.
First off, if you had your motor apart to put in new pistons, you need to leak check it. Intake gaskets are prone to leaking. An air leak will make tuning impossible and in worst cases ruin your new pistons. If you have a tight motor, then it's lean. I'm at 168's on my 28MM PWK's. Runs awesome. -
Mine just used one bolt longer than stock, you'll see wich one when you get to them, it's a cheap part at the hardware store. So are the u bolts and nuts/washers needed to secure the front. Just get some u bolts(2) built for the diameter of your frame and you're done. They are pretty self explanitory once you get them fitted. They may take a bit of smacking around, mine did.
We have done quite a lot of welding chromoly with a MIG and it works great. We make nerf bars and weld up cracks in frames and cages for my 250 Outalw Kage Kart all the time with no problems.
That would have been cheaper for me in the long run after replacing all the A arms and shocks I bent before figuring out I needed so many gussets.
Do you bend your J arms? I only did the conversion because I kept bending J arms. If you do it, it's gonna add some weight, cost a bunch of money, and handle the same. If you do, be sure to make a bunch of gussets and weld them on good. Mine came apart and ruined a new set of shocks.
picture of my Magnum radiator
SuperChris replied to MeanHoTRoD_93883's topic in Banshee Repairs and Mods
You can get a radiator comb for it. It's pretty much just a comb like you'd youse for your hair, only made for radiator fins. Call a rad. shop. -
I had the same problem untill I built a pressure tester. Found that the whole motor was a leak. Fixed it and now the bike is totally different.
No problem dude. There may be a problem I have sooner or later that you can tell me how to fix. I believe that's what these boards are for. I have picked up quite a few little tricks in all the years I have been riding.
A little cool trick is to get yourself a pan of boiling water about three inches deep and soak the rubber in them for about five minutes. It will soften up enough to let them slip right on those 28's. Once they cool, they will retain their new shape. Good luck!
size, price, pic of boots. pic and price on df grab bar
Or timing. Check your key and stator plate also.
Sounds like that may be a someday project.
I was thinking of trying to score a set from a buddy, if I can find any, to make a jig out of. The jig would be simple. A tubing bender would be less than a set of arms. I think I could make a comparable arm at a fraction of the cost. Is there a reason somebody hasn't done this yet?
It's rediculous.
Yes, I called them. The tech sayed they wouldn't work and told me I was wasting my money, but I swear on a stack of bibles, They work good. Ask for late model carbs. Stock jetting put me right in the ballpark.
Recheck your squish, make sure your domes don't have any sharp points, make sure your ignition isn't advanced to far and make sure you aren't running to lean. Any of these things may cause detonation. A properly torqued plug seated in GOOD threads will not come out of a running motor unless it is detonating. The Trinity piece is a good way of making sure that the detonation sticks around long enuph to cause major catastrophic failure. Hope you get it figured out. Sucks to hear about somebody not able to ride because of something so simple as a plug coming out.
Banshee problems spitting up like a hairball!
SuperChris replied to theblackone's topic in Banshee Repairs and Mods
I hope he isn' t running the same plug. -
You do need to put longer studs in a Pro Design Cool head, and it's very simple. From what I understand, they use the same domes so performance wise they'll do the same, Noss claims they cool better though. The workmanship on the Noss head is far superior to the Pro Design Cool Head, uses less parts. That should make it a bunch easyer to take off and put back on. Honestly, I would love to find some sucker to trade his Noss head for my Pro Design Cool Head. That's just me.
