Banshee 79 Posted March 1, 2005 Report Posted March 1, 2005 Hey Just Wanted Your Guys Opinions. I bought Some Pipes Off A Friend, He Also Gave Me Coolheads, Reed Spacers , And A Boost Bottle. Would You Install The Coolheads, Boost Bottle, And Reed Spacers? Thanks For Any Help!!!!!!!!!!!!! Quote
Duninshee Posted March 1, 2005 Report Posted March 1, 2005 Hell yeah you should intall them. Check you domes so that you know what compression you are going to have. Dont want to bend or break anything. Other than that Ride it like you stole it. Quote
Banshee 79 Posted March 1, 2005 Author Report Posted March 1, 2005 Thanks For The Reply, I just Heard That Boost Bottles Dont Help Performance. Wanted Some Opinions. Thanks Again!!!!!!!!!! Quote
MeanHoTRoD_93883 Posted March 1, 2005 Report Posted March 1, 2005 Yes install the reed and the cool heads they give you an increase in performance but im not sure about the boost bootle i have a white brothers boost bootle installed in my banshee and im not sure if i felt something when i installed it for more performance get a airfilter and jetting kit so it will be properly tuned and if you have the extra cash get some Bigger pistons Quote
Banshee 79 Posted March 1, 2005 Author Report Posted March 1, 2005 Yea I Have A K&N With Modified Airlid. People Say The Boost Bottles Cause More Problems Than Good( Rubbing Cables, Cracked Airboots) Thanks For The Reply!!!!!!!!!!! Quote
PUSH THE THROTTLE Posted March 1, 2005 Report Posted March 1, 2005 Definitely install the coolhead, but you Quote
frocashmoney24 Posted March 1, 2005 Report Posted March 1, 2005 yup coolhead will increase performance, but like push the throttle said, we need to know your elevation, other mods and wat size domes it came with along with the kind of gas you plan on running, the boost bottles are shit, throw it out, keep the spacers incase u ever get some larger carbs that need more clearance, other then that they do nothing. Quote
locogato11283 Posted March 1, 2005 Report Posted March 1, 2005 install everything except for boost bottle. Quote
Ducman Posted March 1, 2005 Report Posted March 1, 2005 I wouldn't install the reed spacers, they will make the carbs a litle closer to the air box and make it harder to remove your carbs. They may also add some lag to throttle response. I would only use the spacers when needed for larger carbs to clear the clutch arm or if you want to try them for shits and giggles while trying to dyno-tune every last ounce of HP out of your bike. They are hit and miss weither they help or hurt performance varying between different motor setups. They typically only smooth out power delivery by lengthening the intake to help sync pressure waves in the intake and exhaust earlier and help reduce the dead spot at 5-6k rpm. Somewhat similar effect with the boost bottle. Both may or may not improve performance a slight bit, but will both be in the way to work on your quad. Quote
rocketboy Posted March 1, 2005 Report Posted March 1, 2005 id run the coolhead and spacers for sure ,spacers do work but its alot more noticable on modiifed engines from what ive experianced with them (similar to what ducman stated previously)the boost bottle will boost the manufacturers sales and thats about it,i heard of guys actaully gaining a pony or two by REMOVING the boost bottle on a dyno ,so sell it or give it to the cat to bat around the house Quote
ellison445 Posted March 1, 2005 Report Posted March 1, 2005 I would install all and scrap the boost bottle! Quote
banshee0044 Posted March 2, 2005 Report Posted March 2, 2005 throw away everything but the boost bottle and then....your shit will rip Quote
Banshee 79 Posted March 2, 2005 Author Report Posted March 2, 2005 yup coolhead will increase performance, but like push the throttle said, we need to know your elevation, other mods and wat size domes it came with along with the kind of gas you plan on running, the boost bottles are shit, throw it out, keep the spacers incase u ever get some larger carbs that need more clearance, other then that they do nothing. 331585[/snapback] Thanks for the replies, i havent got them in the mail yet so not sure on dome size. I am 927 feet above sealevel, cut airbox lid, K&N Filter with Precharger, FMF Fattys, Powercore Silencers, I think he said the domes were 19 or 20 cc. but not sure, Thanks for the help!!!!!!!!!!! Quote
