MeanHoTRoD_93883 Posted February 28, 2005 Report Posted February 28, 2005 i just replaced my stock radiator with a magnum it was great and after a week my turbo impellar got spoiled so i replaced it and im up to this is my radiator in a condition the can be used or do i need to replace it from what are these things coming from over heat? Quote
MeanHoTRoD_93883 Posted February 28, 2005 Author Report Posted February 28, 2005 here is a picture of the radiator Quote
Wallrat Posted February 28, 2005 Report Posted February 28, 2005 Your fins are getting bent from hitting flying debris (roost, rocks, bullets, etc). Straighten out the fins CAREFULLY with flat blade screwdriver or a toothpick. Then invest in a cover for your radiator...it'll last longer. Oh and yes it can still be used, even if you don't straighten the fins you've still got probably 96% efficiency. Quote
BenBB Posted February 28, 2005 Report Posted February 28, 2005 I agree with Wallrat, radiator looks good. If you're running that and a PD impeller, even in triple-digit temps you should be fine...unless the jetting is off, I'd double check it. Good luck. Quote
SICK BOY Posted February 28, 2005 Report Posted February 28, 2005 I agree with Wallrat, radiator looks good. If you're running that and a PD impeller, even in triple-digit temps you should be fine...unless the jetting is off, I'd double check it. Good luck. 330929[/snapback] I say the same thing. Quote
Cotton eyed Joe Posted February 28, 2005 Report Posted February 28, 2005 I say the same thing. 330931[/snapback] And I'll kick in another "I agree". I've been using a small #2 flat blade like WallRat said, and I've also been using a dental pick type tool as well. I use them both. The pick for the really fucked up fins, and then use the flat blade against the other side to hold it flat. Works okay. Quote
SuperChris Posted February 28, 2005 Report Posted February 28, 2005 You can get a radiator comb for it. It's pretty much just a comb like you'd youse for your hair, only made for radiator fins. Call a rad. shop. Quote
Cotton eyed Joe Posted February 28, 2005 Report Posted February 28, 2005 You can get a radiator comb for it. It's pretty much just a comb like you'd youse for your hair, only made for radiator fins. Call a rad. shop. 330958[/snapback] There is a radiator repair shop about 100 feet from my shop, and he said he didn't have one that small. I know they make them...and I've seen them for motorcycle and atv radiators, but I can't remember where now. Maybe Eastwood has them Quote
bansheekid409 Posted March 1, 2005 Report Posted March 1, 2005 Your fins are getting bent from hitting flying debris (roost, rocks, bullets, etc). whats he clint eastwood cought in the gun fire? Quote
broke Posted March 1, 2005 Report Posted March 1, 2005 whats he clint eastwood cought in the gun fire? What??? Quote
