FUTURE Posted February 27, 2005 Report Posted February 27, 2005 (edited) Hi guys. I Edited February 27, 2005 by FUTURE Quote
hamuel Posted February 27, 2005 Report Posted February 27, 2005 leak on the intake side? or a left seal went to shit? Quote
SuperChris Posted February 27, 2005 Report Posted February 27, 2005 I had the same problem untill I built a pressure tester. Found that the whole motor was a leak. Fixed it and now the bike is totally different. Quote
RBD Posted February 27, 2005 Report Posted February 27, 2005 It could also be a jetting issue.... Quote
banshee boy 98 Posted February 27, 2005 Report Posted February 27, 2005 post a pic of the piston, so we can see it? did you do a leak down test? what is the compression on the motor? what fuel are you running? Quote
FORMULASPEED Posted February 28, 2005 Report Posted February 28, 2005 Does the right cylinder plug have spots on it? Quote
scotts96fast Posted February 28, 2005 Report Posted February 28, 2005 post a pic of the piston, so we can see it? what he said Quote
FUTURE Posted February 28, 2005 Author Report Posted February 28, 2005 Not yet done leak testing ( tools no available in here ) I believe jetting is fine Today I will post pic of damage piston. Simply it has a whole in the top with scratch in the sides Compression left side Zero , right side 135 thanxx ) Quote
jeffro189 Posted February 28, 2005 Report Posted February 28, 2005 it is running lean ,lean, lean on the left side. look for an air leak ( can use starting fluid and spray aroud, and idle will change) or jetting in carb, or jet is somewhat restricted in the carb. few things too look for Quote
Fireman-hott Posted February 28, 2005 Report Posted February 28, 2005 http://www.mztech.fsnet.co.uk/workshop/wrk_piston.html Match your piston to the picture and theres your problem. This link should be a sticky anymore. Quote
Holyman Posted February 28, 2005 Report Posted February 28, 2005 Your crank could also be twisted allowing only the one side to be advanced too much. Quote
FORMULASPEED Posted March 1, 2005 Report Posted March 1, 2005 http://www.mztech.fsnet.co.uk/workshop/wrk_piston.html Match your piston to the picture and theres your problem. This link should be a sticky anymore. 331120[/snapback] Nice link Fireman, I didnt have that one. I agree that should be a sticky, There needs to be more things like that here. I have a link to I would like to share. Its the longrod crank rotation. There is a notes tab on the right of the animation too. >Longrod animation< Quote
