watkins Posted February 27, 2005 Report Posted February 27, 2005 Hi, I need to change the oil in the banshee.. the dealership told me to use Maxima 85W... does this sound correct? Also... how much oil does the banshee need? Quote
MILO Posted February 27, 2005 Report Posted February 27, 2005 (edited) the dealer will tell you to use whatever he has sittin' on his shelf mine just happened to be what i was looking for anyway- belray gear saver 80w 2 cycle tranny oil. and you'll need about 1.5 quarts for the change. Edited February 27, 2005 by MILO Quote
TREELIZARD Posted February 27, 2005 Report Posted February 27, 2005 Go to the auto parts store and buy 2qts. of automatic transmission fluid type F also known as ATF type F. drain your old transmission fluid and add the two quarts, the little bit extra fluid will help keep your ball from welding to the clutch rod and it wont hurt anything, i've been doing it this way since 2001 and havent had a bit of problems. and its a lot cheaper then the fluid that you will buy at the dealer. Quote
PUSH THE THROTTLE Posted February 27, 2005 Report Posted February 27, 2005 belray gear saver 80w 2 cycle tranny oil. and you'll need about 1.5 quarts for the change. 330265[/snapback] That's what I run but there are many people who run many other things, you need to pick one that you can get easily. Most dealers carry Belray and it's not that expensive. Quote
ledofthezep Posted February 28, 2005 Report Posted February 28, 2005 That's what I run but there are many people who run many other things, you need to pick one that you can get easily. Most dealers carry Belray and it's not that expensive. 330390[/snapback] Bump! Bel Ray 80w here too. 330995[/snapback] Me 2...I ran Valvoline 10w30 with my stock clutch until it burnt out,...then when I put in my dirtdigger I switched to the Belray 80w gearsaver...no complaints. I run about 1.75qts. Quote
bansheetroy Posted February 28, 2005 Report Posted February 28, 2005 i use 20/50 motor oil castrol gtx toomey reccomends this Quote
blk02banshee Posted February 28, 2005 Report Posted February 28, 2005 I used to use spectro-4 10w-40 and switched to valvoline 10w-40 ATV oil. Quote
rockgc9 Posted March 1, 2005 Report Posted March 1, 2005 Bump! Bel Ray 80w here too. 330995[/snapback] I'm using it too.... Quote
BenBB Posted March 1, 2005 Report Posted March 1, 2005 Chevron 80W90 here, can't beat my price on it (free from work haha) and I'm still on the stock '96 clutch after I personally put almost 5 years of abuse on it, heh. Everybody's got an opinion on what to throw in there but I think everyone will agree that sticking with one brand/type of oil and changing it often is your best bet... Quote
ledofthezep Posted March 1, 2005 Report Posted March 1, 2005 Chevron 80W90 here, can't beat my price on it (free from work haha) and I'm still on the stock '96 clutch after I personally put almost 5 years of abuse on it, heh. Everybody's got an opinion on what to throw in there but I think everyone will agree that sticking with one brand/type of oil and changing it often is your best bet... 331696[/snapback] I agree on that last statement. I ran a stock clutch for probably around 5 years too. It wasn't slipping noticeably when I replaced it; then I got to see how much it was really slipping, I was amazed...almost scared. Quote
Ducman Posted March 1, 2005 Report Posted March 1, 2005 Bel Ray gearsaver here too, 1.8 quarts. Stock clutch is still holding up on my 4 mil, for now anyways. Quote
BigRed350x Posted March 2, 2005 Report Posted March 2, 2005 I am running the ATF in mine and don't have any complaints. Cheap too. Quote
RNBRAD Posted March 2, 2005 Report Posted March 2, 2005 Chevron 80W90 here, can't beat my price on it (free from work haha) and I'm still on the stock '96 clutch after I personally put almost 5 years of abuse on it, heh. Everybody's got an opinion on what to throw in there but I think everyone will agree that sticking with one brand/type of oil and changing it often is your best bet... 331696[/snapback] Ben, Chevron makes a killer oil, best refined and the standard in additive packages. Generally everybody else gets their leftover package after their patent expires. So they are usually several yrs ahead of the game. Chevron for a standard dyno oil is probably the best oil produced. Quote
racer Posted March 2, 2005 Report Posted March 2, 2005 im currently running honda's gear oil. its what all my buds put in their CR's so i got some. plus it was sponsored by my employer. Quote
