GSXR 1000 Posted February 21, 2005 Report Share Posted February 21, 2005 Put 34mm carbs on the shee and was wondering why the trottle is so hard to push?Will the springs loosen up or is there another fix cause I can not ride all day my thumb gets way to sore.Was thinking maybe twist throttle any opions or fixxes? Thanks in advance Quote Link to comment Share on other sites More sharing options...
bkabina Posted February 21, 2005 Report Share Posted February 21, 2005 I like the twist throttle and will not be switching back.But it is what you like that matters.You can cut some of the spring off so it isnt so long,probably the best way,but some people also grind some off the sides of the springs too. Quote Link to comment Share on other sites More sharing options...
Machwon Posted February 21, 2005 Report Share Posted February 21, 2005 I usually cut the carb springs so that there is only one extra coil of spring when the slide is in the idle position and remove the spring from the thumb throttle. Works fine from there. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 21, 2005 Report Share Posted February 21, 2005 cut a few loops off the springs or go little by little until you can stand the throttle pull...works like a charm. Quote Link to comment Share on other sites More sharing options...
FORMULASPEED Posted February 21, 2005 Report Share Posted February 21, 2005 You can get an extended billet thumb throttle from mod quad or magic racing. Quote Link to comment Share on other sites More sharing options...
islandsurfer Posted February 21, 2005 Report Share Posted February 21, 2005 remove the spring from the thumb throttle. Works fine from there. 327000[/snapback] Works great for me...That was all I did and rode for hours on Saturday.. Quote Link to comment Share on other sites More sharing options...
BdBanshee Posted February 22, 2005 Report Share Posted February 22, 2005 I just clipped a few coils off of the springs, big difference. Quote Link to comment Share on other sites More sharing options...
RNBRAD Posted February 22, 2005 Report Share Posted February 22, 2005 You can get an extended billet thumb throttle from mod quad or magic racing. 327115[/snapback] I did this also, made a big difference. I new throttle cable can also make a huge difference if yours is old. Quote Link to comment Share on other sites More sharing options...
