i have a ported shee it runs pretty good.
My question is should i gear up for 300ft
or gear down?just wondering what direction
to start heading to get it dialed in.
I will be changing tires also but want to know if
i need them to spin faster out of the hole or gear down and spin slower
right now i run 16/41 and on gps i hit 101 this set up seems like
good top end just want to know if it will work for sand drags.
Thanks in advance
I know this is a shee site. But with all the help I got here for the shee
I figured someone might know the answer.My wife rides a bruin 350
she wants to try twist throttle cause her thumb gets sore riding all day
does any one know where to get a twist throttle for this bike or will
any one work?
Thanks
Put 34mm carbs on the shee and was wondering why the trottle is so hard to
push?Will the springs loosen up or is there another fix cause I can not
ride all day my thumb gets way to sore.Was thinking maybe twist throttle
any opions or fixxes?
Thanks in advance
I live in FL. a lot of the trails are sand some are hard packed with tree roots.
My ? is what front tires do you recommend for this? The problem is when I
roll through a tite turn the front end pushes and sometimes I bounce off trees.
On my old shee I ran 19/6/10 HS mx it turned good but I could feel every bump
in the bars what do you guys recommend?I thought about the 20/6/10 but don't
know if I will still feel the bumps in the bars. any advice will be helpful
Thanks in advance
What is better for a stock motor with just a set of V-force reeds?
Some say T6 for stock motor others say cpi so now I will
ask the experts. Please help thanks in advance
Depending on how dull they are I use
armoral tire foam spray it on let it foam up
and just wipe it down don't wipe off just
enough to make it an even coat and let it dry.
Bouns if you ride a lot in hot weather it will also
keep your plastics protected so they don't get dried out
and crack easy when you crash also will remove stains in the plastics
I run shredders on the rear and like the way they hook up better than holeshots
But have no idea what to run on the front trying to find something to
keep the front from slpding in the corners
I have to say its all about the rider.. When I raced the other day
we were trying different things and if the shee left in 1 gear and the 450 in 2 gear
we were pretty close to dead even but when both left in 2 gear the shee by
several bike lengths also changed bikes where i rode the 450 and he rode the shee same results
I have an 04 shee with pipes ,15t front ,v-force reeds and decked head
got 81mph out of it on gps just curious if this is good or down for what mods i have
thaanks agian sorry if this has been posted before
