Ok as most of you know, my banshee recently had a spark problem, and i threw a new coil on and it ran fine.......... WELL WELL WELL 15 mintues of riding time later , I park it in the garage, go buy a jet, install it, go to start it and it wont fire... it has week spark AGAIN , once every 7 kicks, so i put new plugs and stuff in, and I think its my coil AGAIN because it has NO SPARK NOW
I have experienced three stators go bad on various quads/bikes. All three tested out fine according to the book, but once I replaced the stators, all problems were fixed. If possible, borrow a stator that you know if good and put it on your quad to see if your problem goes away.
The testing specs for the coil in Clymers is way way off. I don't know what the proper specs are, but a brand new coil won't even test anywhere near the values listed in Clymers.
I replaced my coil when I got mine didn't fix it. Then I replaced the CDI and it ran great for about a week then in the middle of the ride it shut down with no spark. Replaced the stator and no problems since. All these electrical parts need to work together or else you are chasing your tail. You fix one thing it works great but then the next thing fails. I say replace it all and be done with it.
One thing comes to mind is corroded connections and bad grounds. I think that sometimes replacing parts fixes the problem only because grounds and connections are redone in the process.
Ron
Ron
316974[/snapback]
My friend had a problem like that his stator crapped out
