I have heard of running a different chain and sprockets besides the 520 style. Has anyone tried using different chain and sprockets that are stronger. My sprockets wear out in about 5 weekends at glamis. What will fit the banshee?
Try the Sidewinder Ti-Moly rear with tool steel front. Pricey but will last. I wore my stock sprockets out after just a few trips. Still on the Sidewinders with no visible wear after a full summer at the dunes.
You can get 525 or 530 chain specially cut for you, but you will be paying about twice the cost. You should look in to Vortex sporkets. I have them on my bike and I have had them running two years with about 15 desert trips. Good luck
Don't run aluminum rear sprockets. Any Stainless steel rear sprocket will last longer than a standard steel sprocket reguardless of brand.
Duncan Racing runs 530 chains on their Banshee that they race in the 12 hour Point de Vaux in France. Give them a try.
Edited by Tim C
its more moving mass to overcome. id sitck with a quality 520 o-ring. as for sprockets i buy primary drive cause they are dirt cheap. if you fuck up a rear, 14.99. if the front goes too thats 7 bucks. cheap sprockets and an expensive chain is the way i roll.
I am just going to get a 15 front and a 45-46 rear then. I figure that more teeth will be able to spread out the power.
287845[/snapback]
don't run the 15-45 your ratio will be 3 to 1 and your sprockets will wear faster because of the even ratio.
