In part thanks to all of you, I ended up getting the 03 Ltd Shee today. Its all stock except for a boost bottle on it, but needs some good general maintenance.
I figure that after I give it a full mechanical checkup, oil change, plugs, lube/grease and a good wash I ought to start putting some mods on this thing. What are the top 5 easiest/most effective/most worthwhile projects I should take on first?
Thanks, Q
22 inch pure sports bandit xc tires. rocket pipes with K&N filter and remove air box snorkel, also find a place to jet hot coat them, carbon tech or delta V force reeds, then i would get PRM skid plates and pro grip gels and maybe later a port and head mod. But get the pipes first :). If you do low end riding id get the Toomey T5's, i dont like fmf for banshees andbesides the banshee is a top end machine so get rockets.
buy a clymers manual
ditch the stock air filter,they like to pop off and suck in dirt and kill your top end.noss machine makes an adaptor plate for k&n's or foam filter
pipes and rejet,acording to what you ride in,fattys are great for trails
advance timing,either mod your stock stator plate or buy a ricky stator for 130$ and sell your old one to recoup some of your money thats what i did "thanks meat"
tires,to suit your riding terrain.razors are good for trails and loose dirt
hope this helps.you made a wise choice,wow do you like it so far?
1st- thing you need is a Pro flow kit. Lose the junk stocker (i have one for sale pm me if interested)
2- get some pipes that match your riding style
3- new rear tires for sure
4- reeds
5- billit water impeller
Alot depends on where you're gonna ride, and how much you want to spend...
1. Air filter-there's a good reason it's on everyone's list, the stock setups sucks. Foam filter or K&N, carb mounted or in the airbox with an adapter plate.
2. Reliability-lots of little things you can do, but my favorite is a temp gauge. Adding grease zerks to the axle housing and swingarm pivot are a close second, then there's removing the TORS and adding skidplates.
3. Suspension-probably the most expensive but also where you can make a big difference, aftermarket front shocks would probably be my first suggestion, followed by (or ideally at the same time) wider a-arms, and a wider axle.
4. Performance-pipe it and rejet. After that, you're only limited by $$$, shaved head/aftermarket head, reeds & ported/aftermarket cages, advance the timing, porting, etc.
5. Traction-rear tires are a must, depending where you ride. The right combo of fronts & wheels all the way around help alot too.
#1..REPLACE THE AIR FILTER!!!!!!!! (lol, the stocker set up is JUNK)
#2. Pipes (ANYTHING is better then stock, everyone has their favorite)
#3 tires...(do some research on what would work best for your riding...)
the rest is pretty trivial....once you get these done, youll know what to do next.
I did the top three, then did trinity single carb, temp gauge and then cosmetic stuff.
