  • 2 weeks later...
send your rad vales back they make you loose around 2 hp lol i got set on my shee only because i sold my v force to customer who didnot want to wait but i love runnign fattys on all bansee i build do u also get jet kit to match if not i recmend geting a k&n power kit and run the 280 jet it sould be close to what you want hope this helps u later drew :bolt:
i run fattys and rad valves but i have the ported to an inch of there lives.when my she was mostly stock it had very snappy throttle response but i had to perfect my jetting with alot of trial and error.i still use them with all my other mods i added.maybe some day ill get vforces when im rich and famous.my shee with just pipes,rad valves,air box lid off,at sea level i ran a 300 main.depending on your elevation it might be a good place to start on the main size.
well it is all together now
i have kn filter in box
fmf fattys
fmf power core silencers
rad valves
and jetted 280
i also put on some mudlite tires wich were a bit bigger...
i will say it hauls ass now and it will do untill i have money to do a stroker kit........
( see not bad for a dumb CANADIAN)
  • 2 weeks later...
Great choice on the Fatties and the powercore 2's!!! :clap:
I run that setup too and I love the torque and pull my Shee has. I know with a great tire for grip its gonna be a beast. My 26mm carbs are jetted 260 and had no problems. They are right ..wd40 is a good deal for protecting your pipes. When they dull from no polishing for a while I use never dull to bring out the shine to my pipes and finish the cleanup with a light coat of the wd40.
I dont know why people dont like these my riddinf budy runs a 2001 shee and he has the toomet t6 pipes and delta reeds with reed spacer and a cone filter
i run a bored 30 tho over 94 shee with fatty pipes and power core silencers and rad valves with a cone filter
when we race i beat him no problem even if i have a bad start i still beat him
i am more than happy with them
  • 2 weeks later...
