BR8ES or B8ES?
the heat range on the plug is the same .. the only diffrence is the br8es will not cause as much interference with things like tvs, radios , phones ect ect . the b8es will cause all kinds of interference .
Depends on what cdi your running. Stock cdi's will work with b8es, but aftermarket cdi's might malfunction. If you've got a totaly stock ignition system..b8es will work..but if your running aftermarket coil, cdi, or even plug boots..might want to run the r type spark plug.
B8ES work with the stock setup because the stock plug boots have resistors in them so a non-resistor plug will work fine. If you change the boots out then you'll need to run BR8ES. BR8ES and B8ES work exactly the same, no diff in performance or anything. When in doubt, run BR8ES.
Later.
