RV00GT Posted May 29, 2004 Report Posted May 29, 2004 I can't decide what to do with my head. Everyone is telling me get the head shaved, get it ported, get a noss head. What is the best option? Quote
Justintoxicated Posted May 29, 2004 Report Posted May 29, 2004 white chicks give the best head... Quote
streetshee Posted May 29, 2004 Report Posted May 29, 2004 dont get your head shaved ull look like a nazi! Quote
frocashmoney24 Posted May 29, 2004 Report Posted May 29, 2004 haha, im dying here and tryin to type at the same time, shits not workin out! porting a head does shit to a 2 stroke, if u dont have alot get the head shaved, bump up ur compression, if u have cash get a noss, look great, keep it cooler, adds some bottom ened grunt, and u can interange the domes hwen u want, and cheap to fix if one gets dinged up Quote
RV00GT Posted May 29, 2004 Author Report Posted May 29, 2004 How much better is a noss head compared to a stock head ported? Quote
Nighty Posted May 30, 2004 Report Posted May 30, 2004 Any aftermarket head will go somewhere around 200$ Some include a set of domes some do not. A set of domes will be around 50$ give or take 10$ Domes are the compression chambers. a banshee head gets shaved (materiaal beeing removed from the base of the head to lower the head, creating a smaller dome/compression chamber) giving you more compression. a head shave job at your local barber (boonman) will be MUCH and MUCH cheaper. He did mine.. great work still have to test it but it looks good. If i am not mistaking he does the shave job for 35$ Quote
sredish Posted May 30, 2004 Report Posted May 30, 2004 compared to a stock head ported? when did we start porting heads, I want in, can I play too?? Can't port two stroke heads, cause there ain't no ports to port. If you have any spare cash, get an aftermarket head, Noss head, PD Coolhead. I'd go with the Noss cause of the BHQ support and the sweet color options. If money is tight, there's nothing wrong the milling the head to get the compression you want, but a an aftermarket will help equalize the extra heat with the raised compression, it looks cool, and you can always raise or lower the compression later, where with a milled head, you got what you got. Later. Quote
RV00GT Posted May 30, 2004 Author Report Posted May 30, 2004 I'm a little new to this 2 stroke thing, but learning something new everyday, thanks Quote
Oilsmoke Posted May 30, 2004 Report Posted May 30, 2004 (edited) A good place to start is milling your head. you can sell it later if you would want better cooling. there are a few Memebers at the Hq that can mill it for you for a fair price. Edited May 30, 2004 by Oilsmoke Quote
fixitrod Posted May 30, 2004 Report Posted May 30, 2004 Start here to get an idea of how two-strokes work.. it's a great web page http://science.howstuffworks.com/two-stroke1.htm Quote
PassionRE Posted May 30, 2004 Report Posted May 30, 2004 Long term best choice for flexibility and options....NOSS pure and simple...Jim Quote
crazymx511 Posted May 30, 2004 Report Posted May 30, 2004 I have a full LRD motor, and love my noss head! Works great and looks the best! Quote
KRMit Posted May 30, 2004 Report Posted May 30, 2004 About how much would a Noss head cool the running temp? Quote
sredish Posted May 30, 2004 Report Posted May 30, 2004 an aftermarket will help equalize the extra heat with the raised compression depends on the domes you use. if they're equal to stock, the head will help, if you raise the compression much, the temps will be the same, because the cooling will offset the extra heat the higher compression gives off. Quote
