i am wanting to run 22 in tires for more ground clearance i want it to be geared a little lower than stock would 13 front and 44 rear with 22in tires be lower than stock any advice would be great thanks alot
Do not use a 13. Use a 14-44+ set up.
The 13 is bad on the chain guide up front.
Also watch the rear skid plate. The chain may hit if the rear sprocket is too big.
I have a buddie that is running 22s you should be fine with 14-43.
that is geared a little to high for me i was wanting it to be a little lower than stock ar at least stock and 42-13 is just right acording to my math how many links of chain will need i have a stock lenth swing arm will i need more chain then stock or the same or what
hey im in need of some help i love my banshee but for were i ride i drag it real bad i an wantin to go to 22in tires and also gear it a little lower than stock i have figured out what gearing i want for teh 22in tires i want either 44/14, 41/13 either of thoses with 22s will be around stock and the 42/13 is a little lower than stock if i go with the 44/14 will i have problems with it clearing th skid plate in the rear and will the 13 interfere with the chain slid also what chain is the best for the money i dont care if it is heavy i want it to be strong i weight over 300lbs so i dotn want it to strach and how many links will i need for the right gearing thanks alot
The best chain I've found id the D.I.D X-ring gold 520 chain. Match that with sunstar or sprocket specialist STEEL sprockets and you will have a good setup that will last. I order 110 links and cut the rest and save them if i ever need them. So far I haven't and I have a few old chains lying around that are still good. Get extra master links. TM design works make a great chain guide system for the banshee..worth twice it's weight in gold. I recoment you replace the stock swing arm chain slider with the TM one. 13 won't interfere with the chain slider as banshee's used to come stock with a 13/41 gear ratio. I recomend a 13/42 for 22 inch tires.
14-44 is what I would run with 22s. Like I said I do have buddies that are running
14-43 and 14-44 setups. But you pick what you like. I know from doing this
myself that a 13 is not good on the slide. I too have a 99.
  • 2 weeks later...
I have 22" itp holeshots and have no problem running stock rear sprocket w/a 15t front sprocket w/stock chain. The clearance is nice, and I think it actually pulls better w/the 15t. I do have pipes and mild motor work done, but nothing extreme (Yet!)
I know from doing this myself that a 13 is not good on the slide.
ive run a 12 tooth on mine for like 2 years and never had any problems. i run the primary drive cheap ass sprockets with a stock cheap ass chain roller and never once had a problem with either. what kind of problem did you have with yours??
Run whatever you like but I run the 15-41 and it does the best with a 20 inch tire. You might like the low gear but I don't like shifting gears that much. I also know guys running 15-41 with 22's and it does good also.
