DirtGrrl Posted February 28, 2004 Report Posted February 28, 2004 jesus i love my bike more than life itself but ITS KILLING MEEEEEEEEE bought the single carb kit..put it on and when i start it its making some fucked up sound..once u get about a quarter of the way thru the throttle twist (dont know how to phrase that better) its making this horrid hollow sound and gets nothing..pulled the plugs..the right side had smoke coming out of it and its bogging like mad when i hit the gas. cant do much more than idle..HELP? havent been able to ride the damn thing in 4 months.. could it be reeds? im going nuts. HELP??????????????????????????? Quote
evil Posted February 28, 2004 Report Posted February 28, 2004 HAVE YOU JETTED IT FOR THE SINGLE OR JUST DROPPED IN THE CARB AND FIRED IT UP. REEDS WOULS CAUSE IT TO MESS UP ONE ONE SIDE OR ANOTHER AND NOT GIVE IT CRISP THROTTLE RESPONCE, ARE YOU HAVEING THAT PROBLEM ? LET ME KNOW WHAT MODS AND SUCH YOU HAVE AND ILL GIVE YOU AN IDEA AS TO WHERE YOU NEED TO BE. LATER Quote
DirtGrrl Posted February 28, 2004 Author Report Posted February 28, 2004 hey!! i start it up anf when u give it throttle it bogs down and doesnt get above idle. had 34mm dual carbs and went to a single carb kit..we went with what they sent us..but the reaction were getting now is the same reaction we got from the dual carbs..it just wont rev up..it bogs and makes this hollow FUCKED up sound. i dont know how to explain any better. any ideas?? thank you SO much for the reply btw Quote
Travis's Banshee Posted February 28, 2004 Report Posted February 28, 2004 Might want to check the float level too. I made that mistake when I put my single on. It was way low. This is probably a dumb statement, but make sure the intake tract is clear. Had a buddy stick a rag in the air box while he was cleaning it and forgot to take it out when he put the filter on. After I installed the single. It took the best part of the afternoon to get it dialed in the way I wanted, so don't give up. Its really worth it when your done. If you get to frustrated, I'll take it off your hands. Quote
Meat Posted February 28, 2004 Report Posted February 28, 2004 yea but she had the same problem with her dual 34s. Time to troubleshoot. start off with a compression check, maybe you have topend problems. You just had your carbs off, did you check your reeds ?? Did you install the intake gaskets ?? BR8es or B8es spark plugs gapped somewhere between .028 and .031 and buy some new plugs just so we can eliminate them as being your problem. we'll figure it out dont sweat it Quote
frocashmoney24 Posted February 28, 2004 Report Posted February 28, 2004 yea its no biggie, everyone has a problem with there shee sometime, waht size carb did you get for the single setup anywa 33, 35?, but check if ur reeds are cracked or flaking, then check ur compression make sure there both about 10 psi within each other, make sure ur filters are clean, new plugs, new gas, and try it out Quote
. Posted February 28, 2004 Report Posted February 28, 2004 Just a thought, do you still have your parking brake hooked up? Quote
BenBB Posted February 28, 2004 Report Posted February 28, 2004 OK if you're changing carbs you know you'll have some trial and error there dialing it in, BUT if it did the same thing with the last carbs you need to find that problem before doing any jetting. Some good ideas here already, you either need to start tryin' stuff or try and narrow down the problem for us. I'd start with electrical like . said, sounds kinda unlikely but is the whole TORS system gone? Control box above the left cylinder and e-brake switch? Check reeds & intake gaskets? Check compression? Try new plugs? Check for air leaks on the new manifold? Air filter clean? (sorry, along with not turning the fuel "on" it happens to all of us) If all that checks out I'd start on the jetting, sounds like the main and/or needle may be way rich... Quote
blk02banshee Posted February 28, 2004 Report Posted February 28, 2004 Just a thought, do you still have your parking brake hooked up? That's what it sounds like to me also. If it is hooked up, try playing with the P-brake and switch. might not be it, though, cause is'nt that part of the tors system? I'm sure she had to disconnect the tors to run 34s or single carb. Quote
ranshee Posted February 29, 2004 Report Posted February 29, 2004 When i removed the tors plugs off of my carbs thw bike ran fine, but when i did the clutch perch mod and removed the switch from the e brake the bike made the same sound you are refering to. When i unpluged that switch the bike ran fine. So i think you might want to just check that out just to be shure Quote
DirtGrrl Posted February 29, 2004 Author Report Posted February 29, 2004 ok guys..evil called and gave us some tips..were getting new reeds on tues (bike shops out here are closed sun and mon..) oh and EVIL U ROCK also..my parking brake is still attached..i had pulled mine off my blaster but when i went to pull the one off the banshee we couldnt figure out how to pull the damn thing off..hubby is out right now trying to get that off..i hope that could be the issue? hey thank you guys alot. i came from cali..the land of banshees to colorado and i dont know anyone (in person) that has em or works on them. hubby has never dealt with a banshee until mine..so u all are a great help especially u sredish and evil. thank you so much.. well try to deal with the parking brake now!!! tonie Quote
sredish Posted February 29, 2004 Report Posted February 29, 2004 ok guys..evil called and gave us some tips..were getting new reeds on tues (bike shops out here are closed sun and mon..) oh and EVIL U ROCK also..my parking brake is still attached..i had pulled mine off my blaster but when i went to pull the one off the banshee we couldnt figure out how to pull the damn thing off..hubby is out right now trying to get that off..i hope that could be the issue? hey thank you guys alot. i came from cali..the land of banshees to colorado and i dont know anyone (in person) that has em or works on them. hubby has never dealt with a banshee until mine..so u all are a great help especially u sredish and evil. thank you so much.. well try to deal with the parking brake now!!! tonie so did it turn out to be the reeds? damn reeds. i feel for you. i haven't been on here much in the last day or so cause i've been trying to dial mine in a little bit. Quote
DirtGrrl Posted February 29, 2004 Author Report Posted February 29, 2004 i dont know yet if it is the reeds..i wont know until tues..damn bike shops arent open..so ill know then. for now i went out and polished whatever i could so it could sit in a somewhat clean dignity until i get it out ..also gathered up all the old parts to sell.. how is your beast running?? hey and thanks again. i owe u big time sredish:) Quote
sredish Posted February 29, 2004 Report Posted February 29, 2004 i dont know yet if it is the reeds..i wont know until tues..damn bike shops arent open..so ill know then. for now i went out and polished whatever i could so it could sit in a somewhat clean dignity until i get it out ..also gathered up all the old parts to sell.. how is your beast running?? hey and thanks again. i owe u big time sredish:) just right. i'm gonna place an order for an axle on monday. i'll probably be buying some new front tires pretty soon also. motor wise, shee's just the way i like her, strong and powerful in the beginning and finished to a nice sweet high. Quote
. Posted February 29, 2004 Report Posted February 29, 2004 You get that parking brake disconnected yet? I know you can pull the rear part out of the caliper but I think you also need to disconnect the wire coming from clutch perch (I believe, I forget, its been so long.) You're gonna need a brake blockoff for the rear caliper, they're like 10 bucks or so, not expensive. Saying that you still have the parking brake installed, makes me think that 99.9% chance is that its the parking brake, its staying engaged and thats what it'll do, as soon as you try to give it gas, it'll just bog and such. Quote
