lian Posted January 6, 2004 Report Posted January 6, 2004 ok ive been searching for pipes i decided fmf but when i look at the dyno charts on fmfracing.com its say banshee is only around 37 or 35 and i alway heard banshees are around that hp stock and how much does the would the silenceser add or do they just take weight off i need to know all this becouse im about to buy my pipes next week thanks for replys Quote
yamaha350 Posted January 6, 2004 Report Posted January 6, 2004 they are probably playing it safe on the hp numbers. dont want to say a higher number just in case someone dyno's there bike and gets a lower number. get the silencers they wil flow better than the stockers, plus its less weight and it will sound better. Quote
lian Posted January 6, 2004 Author Report Posted January 6, 2004 yah i noticed with the pwercores 2 i big difrences in flow execpt the left one did not mount up good one of the tabs was a quarter of inche to the left or somthing that pissed me off has anyone had the trouble with mounting the pipes Quote
dittmer Posted January 6, 2004 Report Posted January 6, 2004 Go take a look at www.toomey.com they have a dyno chart that say the SST makes way more power than what fmf shows on there chart.They show like 51hp or so on toomeys site. There site claims the new TR-6 is made for a stock motor so i can only guess that the dyno charts are from a stock motor. I hope this helps you more than it did me. It just adds to the confusion in my brain Quote
lian Posted January 6, 2004 Author Report Posted January 6, 2004 that was very good to check uh is that the horse power the pipe adds on it say fmf fatty for banshee 25 Quote
2004LEBanshee Posted January 7, 2004 Report Posted January 7, 2004 So with modded air box K&N and Fatty's I have about 50 HP? True or not? Quote
lian Posted January 7, 2004 Author Report Posted January 7, 2004 ahh that chart is confusing too is that mesuring the hp at the wheels or somthing Quote
Aussie Quad Racer Posted January 7, 2004 Report Posted January 7, 2004 it does not state what mods are on these bikes that where dynoed on the toomey site. I know for fact there not stock. Heres what it took to get 50peak rear wheel hp out of a set of pro cuircuits unifilter clamp on filters. stock carbs jetted correctly(we used gas analyser on the dyno to get the right ratios) ported reed cages with carbontech reeds ported intakes and transfer ports matched cylinder to case hot rods crank(for durability) wiseco 40thou over pistons. Shaved head(150 psi cold) Pro curcuits and silencers. Quote
Aussie Quad Racer Posted January 7, 2004 Report Posted January 7, 2004 the chart on the fmf site is a relistic banshee dyno chart of a complete standard bike except for pipes change and main jets to suit Quote
Demon350 Posted January 8, 2004 Report Posted January 8, 2004 i thot the shees wer 40hp + stock and with toomeys 50+ Quote
Aussie Quad Racer Posted January 8, 2004 Report Posted January 8, 2004 i thot the shees wer 40hp + stock and with toomeys 50+ Go and get your bike dynoed if you dont believe me. I would no believe any of those charts. And the other thing is what gear were the runs done in??? All dyno runs on the banshee should be done in 5th gear as this is all but 1:1 ratio through the box. This will give your most accurate reading. Quote
Justintoxicated Posted January 9, 2004 Report Posted January 9, 2004 the toomys will give you more peak HP than the FMF's (T5's vs Fattys) I dunno about SSTs Vs T6's But the Fattys will give you a couple more HP all the way up to the top (more area) than the toomys Just depends what you want... Banshees are around 35HP stock I believe. 40+ might be the power of the engine but not rear-wheel as mentioned. And dynos will varey. As for mounting, banshee frames are not perfect, its probably your frame that is slightly off rather than the pipes. Don't worry though its normal, you may have to slightly tweak the pipe to get it into place. You should also modify your air box and filter at the same time you get pipes. Make sure to re-jet Quote
mattmans1983 Posted January 26, 2004 Report Posted January 26, 2004 DMC DMC DMC DMC DMC DMC!!!!!!!!!!!!!!!!!!!!!!! Quote
Banchetta Posted January 27, 2004 Report Posted January 27, 2004 Take those dyno charts and throw them out the window. You dont' know if those shees are jetted correctly for those pipes....that'll affect the dyno a LOT....Besides, peak hp means nothing....some of the fastest quads have the least hp...Its not how much hp you have, its where you put it.... Quote
