Unfortunatley the guy who makes the manifolds for Graydon Proline had a stroke around Christmas, and is not currently producing them (He's an older guy and lives about 5 miles from me). If / when he starts up again I will let you know. The carb I have is a kehin 35mm PWK air stryker. You can use whatever carb you like.
  • 1 month later...
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
:huh: ok what we are looking at is something that hasnt been around that long. :huh: but does it distribute fuel evenly with the air it is sucking in.think about it.but we have 2 lungs and two holes to breath out of. :blink: but we only use one at a time. unless you use the in with the nose out with the mouth. if you were able to breath out of your mouth and nose together what would be the out come.MORE AIR.THINK ABOUT IT .
CHipdog I understood nothing of what your talking about.
I'm taking a guess on what you said though.
The air/fuel mixing happens in the carb and throughout the pipe. The banshee yeah has 2 "lungs" but unlike human "lungs" the banshee "lungs" work one at a time not both at the same time.
So a single carb can handle that up to an extent.
Hey gonzo is this your bike the purple with yellow?  If it's not it sure looks like your bike.  :blink:
I doubt it man. I got it a few years ago in Pearl, MS.
actually the stock carbs are 26mms and not 28mms...Any aftermarket carb is far superior to the stock carbs. I have the dual LRD Keihn 28mm and i love them...they are so much better than the stock mikunis :whoa::whoa:
  • 11 months later...
I've looked VERY closely at the Trinity 2:1 intake and I've found it to be restrictive. This may be one of the reasons why the 33MM is suggested for unimproved engines. They just can't force enough air thru the intake. Personally, I think the Graydon should flow slightly better but only very slightly. I have been working on a design for a 2:1 intake that should flow better than the Trinity but I've got no-one with machining capabilities to develop a prototype.
148954[/snapback]
did this idea of youres ever get of the ground?if so i would like to hear more about it.
thank you
