willow2679
Everything posted by willow2679
  1. yea maybe, but to me the axis looks trickier than elkas (matter of personal choices I think) :shrug:
  2. That system looks pretty trick But I find strange that Roll design before the elkas allways used C.Axis (even berore elka went out) with those arms and now they say that they always used elkas ?? doug eichner used C.Axis withthem I dont know I think you have to pic the brand of shocks you want but allways being sure that they are for that front end and your riding style and specs
  3. i put it on the picture forum too if you change the spacers you change the caster they are for that but your quad is going to handle different in the lonestar page is one page that is like a tutorial of how to do the changes and what they mean btw now that I see you have upper a-arms with heim joints, you can change the spacers but you have to play with the heims to have the same caster settings setting and maybe clear the pipes but before any adjustment try to find how to do it good and what the changes mean (maybe calling lonestar to have advice) I think you can
  4. thats going very good it was a long time I didnt see an update of your badass shee
  5. the rims are a waste of $$ if they aren`t for MX and if your going big air the spacer are not good for your axle
  6. Steering damper and flipin the wheels then suspension
  7. Have the exact same problem don
  8. Lovely quad and work you
  9. That looks gnarly! good work ! For the allen head take care because those bolts seize by the heat generated by the brakes (I suposse ) to me it was the same, If I remember well I hit the allen bolts with a hammer and a punch or something like that to unstuck them and then tried with the allen wrench and a tube in thye other side to make more leverage Good luck! BTW Nice banshee that cpis looks huge!
  10. that green is pimpin bro. it looks ok to me check the rings for wear to and remove the carbon build up inside the ring grooves too (Btw if you took off the jugs to see the rings chenge them it
  11. My ride is firm not stif it absorbs the bumps real good, but dont know how it works on dunes and your question is a nice one because the whoops that are on dunes by the wind or the ones that form for others riders make it hard and uncomfortable
  12. Nice pics! Practice is the best thing you can do to ride faster on your quad (any quad, keep riding on tracks and ride smart like you do and you can be a very good rider) Sorry I have to said that BTW very nice banshee what bend are that tag bars?
  13. I don`t F
  14. what is atrong arm symetry the brand aof an a-arms? you ahve pics of it?
  15. For what the laeger web page says it still do the banshee protrax frame for the shee it has it there
  16. Nice post did you do something to your a-arms they look like they have negative camber on it with A/M a-arms you can move the lower mounting holes to the outside to let the shocks go fully extended I don
  17. I think the cheetah cubs are the most expensive bang for the buck It needs other carbs or not? other reed valves too and maybe the matching pipes for it
  18. The lighter flywheel gives more throttle response only the bad on it is that if you remove to much it stall easier than the heavier (the heavier one has more inertia that way it dosn
  19. pipes for me too I would consider the stickers too
  20. my frame had that same cracks on the upper mount of the rear shocks they were BIG! But mine I think Ive gotten because I had not servied the rear shock in a long time and wasnt working good the plate that holds the cdi and were the plastics are bolted were realy shot too on mine an the other places that others post too my frame wasnt realy good I think
  21. I think youre all really hard on his banshee I been a long time here but
