Youre not getting fuel to the cylinder then. see if your bowls are filling if so your jets are plugged, if not your float needle/ seat ( fuel inlet isnt ) is plugged / inop.
Sent from my SM-A505U using Tapatalk
On 3/19/2022 at 10:49 PM, Fordmaster101 said:
Got the fly wheel off and New one on both pipes smoke and sounds good . But can only get it to run on starting fluid. The petcock has good flow . But when I connect it to the fuel line it's doesn't come out much at all. Causing the carbs to be dry and not fire . Have checked the lines no blockage floats are 21mm 280 main jet 25 pilot jet. What could cause the fuel to not flow to the carbs ? Oh yes it has gas and yes the filters on petcock are clean .
i once also had a problem with petcock. when i pulled it out of the tank, i saw that the brass tubes were totally corroded and looked like a swiss cheese. that pet cock was probably the main culprit, why the pilot jet on the right sided carb always got clogged. replaced it by an brand new after-market one of good OEM quality...no problems since then!
Seafoam . Disconnect the fuel line spayed air through.  Than poored seafoam in line till filled. Than let sit for an hr . Connected the line again ran the bike till stopped dumping smoke ,Than just repeated one more time and it did the trick.
