Exhaust upgrade
I have a 1993 banshee that I have rebuilt from ground up I went from a stock exhaust to dual FMF Fattys do I need to change the jetting in the carburetor because of going to the FMF fatty‘s and if so what size manger and what size pilot jet thanks in advance for anyone that can help????
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
Stock air box?
fattys I believe like a bigger pilot, if you don’t have an air box try a 30, but I think you’ll be good with 27.5.
main you can safely start at 280 and work your way down.
i would email FMF though, they can set you straight
  • 4 weeks later...
Let me ask you this if I unplug the tors from underneath the gas tank believe the two other plugs plugged in to the idle pieces. Above the carburetors would that make a difference or should I unplug those two seem to idle a little longer before I did the tors delete But I had the pieces above the carbs plugged in but the piece  unplug underneath the tank
