Hey everyone I just became an owner of a banshee and I want to know what would be the perfect build for the road sometimes but majority trailing. I want something that’s fast but also won’t be a burden on the trails.
Currently have Hemi  heads CPI pipes  32mm carbs and a boost bottle
Wondering if I should just do full bolt on and will I be satisfied or stock 4 mill or any other suggestions for the riding that I’m doing. I mostly trail ride on the open dirt roads and also race from time to time   All advice and suggestion are highly appreciated.
58 minutes ago, BansheeUSA said:
Thanks a lot for the advice. The serval would be good for open dirt road?
Ok thanks I will look more into both. Do you have any price estimates for either.
37 minutes ago, ClaudeMachining said:
Yes.
Driveline 421 Low port would be a good choice too.
Envoyé de mon SM-G965W en utilisant Tapatalk
Thanks I will do more research on both do you have any price estimates on both?
Crank, cylinders, pistons, head, misc.. You’ll be looking at roughly $2,000. That also depends on what you already have.
And if your clutch parts are junk, plan on another $350 for a new bracket, inner hub, pressure plate and clutch.
No sense in doing this build and try to skimp on parts.
  • 2 weeks later...
