I already know about the sticky.  I got about a month left of riding season before I wrap things up, so I need only a temporary fix.  Left rear is stripped.  I really only care because its the bolt that holds my chain tensioner on.  Im pretty sure I can drill and tap it up a size, but my question is, should I just cut the old ones out and weld those jds inserts in? Or ive read on here of people drilling the hole out a bit and welding a flange nut in there.  If i go that route do you think I can aluminum braze it with a torch?
Edited by Ayesully810
If i were you i would just get the jds inserts and weld in the one you need for a quick fix but honestly it would be better to just weld all 4 in since you will already have the welder and other tools out. You can drill out the old ones using a stepped drill bit. Tylers SE build thread had some good pictures of what’s required.
thanks Ty
how would you drill out the old ones using a step? dont you have to cut them out around the perimeter where the weld is?
thanks Ty
I didn’t drill. I used a sawzall. One cut. I did both sides start to finish in 15 minutes.
thanks Ty
You can cut them out too but i feel like it would be harder and leave your new welding surface uneven unless you are really careful with a cutoff wheel. This is what i was talking about. Drill it out until you cut through the weld and can slide the new inserts in.
Okay  i see what you are saying. I feel like if i were going to weld the flange nuts in the step drill bit would be a good idea to open hole up with. But this winter I would like to just put new ones in the right way like tyler did
I had a frame in the past where the previous owner drilled out the threads on both sides on the rear hole and fed a long piece of all-thread through the frame and tightened the footpegs on both sides with a nut.  It worked...
Look like Tyler's butt plug.
Envoyé de mon SM-G965W en utilisant Tapatalk
yeah jared i read that in some of your posts i was diggin up old ones, where do you get that stuff at?
I just retapped the threads today and ran a m10 1.5 in there and it works fine, will prolly hold up for a while. real tight.
But like i said id like to do it like tyler did this winter.. what do you weld the inserts in with? tig or arc?
