Banshee 400 Posted October 24, 2017 Report Posted October 24, 2017 I wanna get more power out of my banshee mostly stock now but would going to a 4 mil give a big change in power make it quicker. What can I do to get more power in my banshee? Sent from my iPhone using Tapatalk Quote
Ayesully810 Posted October 24, 2017 Report Posted October 24, 2017 (edited) you can make it a BANSHEE 400 and it will be fast jk but seriously there is a lot of things you can do. yes a 4 mil will make it quicker, but there is more to it than just changing out the crank. Id pick a sponsor on here to do your work and contact them. I would start with after market pipes that will support your riding style, reeds and some advanced timing (adjustable timing plate) also learning to tune your carbs will be a good skill to learn once you start changing stuff Edited October 24, 2017 by Ayesully810 Quote
Banshee 400 Posted October 24, 2017 Author Report Posted October 24, 2017 you can make it a BANSHEE 400 and it will be fast jk but seriously there is a lot of things you can do. yes a 4 mil will make it quicker, but there is more to it than just changing out the crank. Id pick a sponsor on here to do your work and contact them. I would start with after market pipes that will support your riding style, reeds and some advanced timing (adjustable timing plate) also learning to tune your carbs will be a good skill to learn once you start changing stuff As of now I have trinity stage IV and Keihin 34mm pj no air box and the adjustable-timing plate I guess it’s not mostly stock but I want to get more speed out of it Sent from my iPhone using Tapatalk Quote
spurdy Posted October 24, 2017 Report Posted October 24, 2017 What does "mostly stock" mean? How are we going to give advice when we've no clue what you have? Increased timing, displacement, and compression equals more performance. That is a given on a general level. Sent from my iPhone using Tapatalk Quote
Banshee 400 Posted October 24, 2017 Author Report Posted October 24, 2017 What does "mostly stock" mean? How are we going to give advice when we've no clue what you have? Increased timing, displacement, and compression equals more performance. That is a given on a general level. Sent from my iPhone using TapatalkJust stated what i have in my reply...Sent from my iPhone using Tapatalk Quote
specialblend07 Posted October 24, 2017 Report Posted October 24, 2017 Call a sponsor, tell them what you want, pay bill, wait for motor, go ride. This will be the EASIEST route Quote
Banshee 400 Posted October 24, 2017 Author Report Posted October 24, 2017 Call a sponsor, tell them what you want, pay bill, wait for motor, go ride. This will be the EASIEST routeThat’s what I’m planning on doing Sent from my iPhone using Tapatalk Quote
SandSlingerOR Posted October 24, 2017 Report Posted October 24, 2017 Go back to stock carbs, do clamp on filters, install vf4 reeds, I'd even do a stock head mod now, or cool head, for starters. That'll get you ready for when you go 4mill Quote
Ayesully810 Posted October 24, 2017 Report Posted October 24, 2017 (edited) depends on how much you are willing to spend, but getting some porting done with some added compression and some reeds would be your next step. or you could get a 4 mil crank AND have it ported. Will cost a little more but will make more power. the options are endless but will only take you as far as your wallet (or credit card, not advised lol) will go Edited October 24, 2017 by Ayesully810 Quote
kawa110 Posted October 24, 2017 Report Posted October 24, 2017 More top speed? Just change the sprockets.... Quote
trickedcarbine Posted October 25, 2017 Report Posted October 25, 2017 You can port for the stock stroke, or port it for the 4mil. You don't see much gain just swapping the crank. There needs to be a total package to get the benefits of stroke. A good stock cyl 4mil can make mid 70+ hp on pump fuel and 80+ hp on race gas. Quote
JUSTWANNARACE Posted October 25, 2017 Report Posted October 25, 2017 Let's start with, what is your "budget"? That is going to be the most helpful piece of advice for us to give you options.. then what kind of riding do you do? Get us those answers and we can go for there.. and also a total list of what you have now will help as you may be able to improve from what you have. Cause if you have a true trinity stage whatever, usually the cyls have been over ported. And with that said your cyl you have will not work with a 4mm crank.. jmo Quote
Banshee 400 Posted October 25, 2017 Author Report Posted October 25, 2017 Let's start with, what is your "budget"? That is going to be the most helpful piece of advice for us to give you options.. then what kind of riding do you do? Get us those answers and we can go for there.. and also a total list of what you have now will help as you may be able to improve from what you have. Cause if you have a true trinity stage whatever, usually the cyls have been over ported. And with that said your cyl you have will not work with a 4mm crank.. jmo$2000-$2500 on a complete build turn key ready and trail riding and some track riding Sent from my iPhone using Tapatalk Quote
jesseisonbowman Posted October 25, 2017 Report Posted October 25, 2017 If you are mostly on the trail and sometimes MX, you may consider the Moto-Fast single carb manifold, a PWK, and Moto-Fast 2 into 1 pipe. You will have plenty of power on tap throughout the RPM range and they sound amazing. Dyno port makes a 2 into 1 pipe as well and trinity has a single carb manifold but Moto-Fast was the first and the only engine builder to ever win a GNCC on a Banshee. I am in KY and also ride trails and occasional MX. More top end is the last thing you need around here. Moto-Fast Banshees used to give the Hondas fits before Mr Smith had to close the business to attend to personal matters. He is a RD RZ & Banshee guru and works with yamaha directly for R&D. You can find him on ebay selling some old dead stock parts under the seller name 'motojunk' if you message him, he will respond and probably has exactly what you need. Just thought you might want a differentiated prospective. Not sure how rough the trails are in your neck of the woods but a 70 hp stroker would be a handful on the trails around here.Sent from my SM-G930V using Tapatalk Quote
ZillaFreak Posted October 25, 2017 Report Posted October 25, 2017 On 10/25/2017 at 9:37 AM, jesseisonbowman said: If you are mostly on the trail and sometimes MX, you may consider the Moto-Fast single carb manifold, a PWK, and Moto-Fast 2 into 1 pipe. You will have plenty of power on tap throughout the RPM range and they sound amazing. Dyno port makes a 2 into 1 pipe as well and trinity has a single carb manifold but Moto-Fast was the first and the only engine builder to ever win a GNCC on a Banshee. I am in KY and also ride trails and occasional MX. More top end is the last thing you need around here. Moto-Fast Banshees used to give the Hondas fits before Mr Smith had to close the business to attend to personal matters. He is a RD RZ & Banshee guru and works with yamaha directly for R&D. You can find him on ebay selling some old dead stock parts under the seller name 'motojunk' if you message him, he will respond and probably has exactly what you need. Just thought you might want a differentiated prospective. Not sure how rough the trails are in your neck of the woods but a 70 hp stroker would be a handful on the trails around here. Sent from my SM-G930V using Tapatalk No, god no. Moto fast is garbage. Also, full of lies. Moto-fast isn't the only one to win a GNCC on a banshee. Have you heard of Duncan? If you want a single carb, use a yamaha manifold. If you want good low end, use PT pipes. If you really want a good trail/mx engine, talk to DDQ about his setup. Suspension will be key and take most of your 2500 budget. 1 Quote
