Supergrandam Posted October 2, 2017 Report Posted October 2, 2017 My banshee chain recently started coming off, but only when rolled backwards like off a hill. Never comes of in forward motion. Chain is tight. Any suggestions? Quote
special06shee Posted October 3, 2017 Report Posted October 3, 2017 Look at your sprockets. Are the teeth rolled over? How old is your chain? If you have a stock swing arm make sure both sides are adjusted the same. In other words if one side is adjusted more then the other your chain wont have a straight pull. Under load there will be enough tension to keep chain on sprockets but when there is no load on chain it will wanna walk off sprockets. Quote
n2otoofast4u Posted October 3, 2017 Report Posted October 3, 2017 Chain is on backwards You goon! He's got the sprockets on backwards, not the chain!Sent from my SM-G900V using Tapatalk 2 Quote
Keno Posted October 3, 2017 Report Posted October 3, 2017 My banshee chain recently started coming off, but only when rolled backwards like off a hill. Never comes of in forward motion. Chain is tight. Any suggestions?Please elaborate on what "chain is tight" means. Also as stated above, sprockets are junk, and/or crooked. Quote
wr02 Posted October 4, 2017 Report Posted October 4, 2017 If you lift it by the frame and have the axle hang free.. Do the axle bearings have free play? I ran into that once where the bearings were shot and the chain fell off. Quote
