Dalton Posted September 20, 2017 Report Posted September 20, 2017 Hello currently running a dual pingle with my 421 setup and 35PWK's.. Wanting a petcock with a reserve. Could I upgrade carb bowls to oversized and if I did so would stock petcock flow enough fuel to feed carbs adequately? What are your thoughts on this. Thanks Quote
spurdy Posted September 20, 2017 Report Posted September 20, 2017 Hello currently running a dual pingle with my 421 setup and 35PWK's.. Wanting a petcock with a reserve. Could I upgrade carb bowls to oversized and if I did so would stock petcock flow enough fuel to feed carbs adequately? What are your thoughts on this. Thanks Over sized bowls only help out for short term runs. If your racing down a fire road once the bowl is depleted your back to relying on your petcock flow. Sent from my iPhone using Tapatalk Quote
Ayesully810 Posted September 20, 2017 Report Posted September 20, 2017 Pingel makes one with reserve. Bigger bowls won't matter as much as a dual pingel will. Sent from my LGMS210 using Tapatalk Quote
Dalton Posted September 20, 2017 Author Report Posted September 20, 2017 2 minutes ago, spurdy said: Over sized bowls only help out for short term runs. If your racing down a fire road once the bowl is depleted your back to relying on your petcock flow. Sent from my iPhone using Tapatalk Thanks makes sense. Quote
Dalton Posted September 20, 2017 Author Report Posted September 20, 2017 3 minutes ago, Ayesully810 said: Pingel makes one with reserve. Bigger bowls won't matter as much as a dual pingel will. Sent from my LGMS210 using Tapatalk I see that they do. I'll have to call them and find out what specs are....what capacity reserve is. Any one running one? Quote
Ayesully810 Posted September 20, 2017 Report Posted September 20, 2017 I think specialblend is the only one ive seen on here with one Im sure theres othersSent from my LGMS210 using Tapatalk Quote
ZillaFreak Posted September 20, 2017 Report Posted September 20, 2017 You could run a stock petcock depending on what you are doing. If just trail riding and not long pulls you will be fine. Take the stock petcock and mod it. You can open it up some to flow more. Also mod the gas tank cap to allow air in better. Don't want the tank to air lock and not flow fuel. Quote
Dalton Posted September 20, 2017 Author Report Posted September 20, 2017 4 minutes ago, ZillaFreak said: You could run a stock petcock depending on what you are doing. If just trail riding and not long pulls you will be fine. Take the stock petcock and mod it. You can open it up some to flow more. Also mod the gas tank cap to allow air in better. Don't want the tank to air lock and not flow fuel. That's an idea opening up petcock more to flow fuel. I've already opened up the stock fuel cap to flow more air. Works good. Quote
kawa110 Posted September 20, 2017 Report Posted September 20, 2017 There's a thread that shows how to drill out the stock petcock and add a fitting to make it a dual feed Quote
ZillaFreak Posted September 20, 2017 Report Posted September 20, 2017 Just now, kawa110 said: There's a thread that shows how to drill out the stock petcock and add a fitting to make it a dual feed IIRC, doing this removes the reserve feature. 1 Quote
RagunCajun Posted September 20, 2017 Report Posted September 20, 2017 According to recent FB post, a 465 on alky does fine up long hills with stock bowls(39's) and petcock. 1 Quote
ZillaFreak Posted September 20, 2017 Report Posted September 20, 2017 1 minute ago, RagunCajun said: According to recent FB post, a 465 on alky does fine up long hills with stock bowls(39's) and petcock. that guy is a little off. 1 Quote
Dalton Posted September 20, 2017 Author Report Posted September 20, 2017 1 hour ago, Dalton said: Hello currently running a dual pingle with my 421 setup and 35PWK's.. Wanting a petcock with a reserve. Could I upgrade carb bowls to oversized and if I did so would stock petcock flow enough fuel to feed carbs adequately? What are your thoughts on this. Thanks I called Pingle today and the height is about the same between the race version and reserve version....with reserve being about a gallon of fuel. It's about $162 between pingle and adapter plate. I'll probably go this route. Thanks. Quote
RagunCajun Posted September 20, 2017 Report Posted September 20, 2017 1 hour ago, ZillaFreak said: that guy is a little off. But if it works, it works. If it works for others who's set up pull a lot more fuel than small engines with small carbs, then it isnt needed. If it is no needed, then people need to stop recommending parts that people should be buying. Just cut the fuel cap which is free and save money. Quote
ZillaFreak Posted September 20, 2017 Report Posted September 20, 2017 6 minutes ago, RagunCajun said: But if it works, it works. If it works for others who's set up pull a lot more fuel than small engines with small carbs, then it isnt needed. If it is no needed, then people need to stop recommending parts that people should be buying. Just cut the fuel cap which is free and save money. It is better to be safe than sorry. 1 Quote
