Canadianshee Posted July 27, 2017 Report Posted July 27, 2017 So a compression change should not effect the plug gap spec requirement. I guess what I'm trying to ask since I've installed 21cc dome my compression has increased over stock does the oem gap still apply, or should a different gap be used. Its just a question after reading through this thread, I assumed that plugs come pre gapped, but checked 4 sets I had just now, not a single one was within spec (BR8ES type) from the dealer. Going to double check here on in. Sent from my LG-H831 using Tapatalk Quote
ClaudeMachining Posted July 28, 2017 Author Report Posted July 28, 2017 Those ground straps are sexy Envoyé de mon SM-G935W8 en utilisant Tapatalk 1 Quote
kawa110 Posted July 28, 2017 Report Posted July 28, 2017 Head to frame? Cylinder base to frame? Quote
ClaudeMachining Posted July 28, 2017 Author Report Posted July 28, 2017 This is my engine/frame ground.This one is the hotwire ground on the engine headEnvoyé de mon SM-G935W8 en utilisant Tapatalk Quote
Canadianshee Posted July 28, 2017 Report Posted July 28, 2017 Should try to put double wall shrink wrap on to help keep it clean Sent from my LG-H831 using Tapatalk 1 Quote
Profilact Posted July 28, 2017 Report Posted July 28, 2017 On 7/26/2017 at 6:32 PM, ClaudeMachining said: Dunno about power increase. The curves shifted for sure, i still have room for comp, will try 19cc and 18cc soon. I m at 155psi with 20cc and 100ll right now. Envoyé de mon GT-P5113 en utilisant Tapatalk Claude, It sounds like you and I have very similar engines. I started out my build running 100ll also. I started with 20cc domes and it was too much compression for the octane rating of 100ll. I was backing plugs out... Just saying to be careful here. I think I was at 180 psi with 100ll at the time. I ended up going to 22cc domes for reliability and longevity. I didnt miss the extra down low grunt from the switch all that much. Quote
ClaudeMachining Posted July 29, 2017 Author Report Posted July 29, 2017 2 hours ago, Profilact said: Claude, It sounds like you and I have very similar engines. I started out my build running 100ll also. I started with 20cc domes and it was too much compression for the octane rating of 100ll. I was backing plugs out... Just saying to be careful here. I think I was at 180 psi with 100ll at the time. I ended up going to 22cc domes for reliability and longevity. I didnt miss the extra down low grunt from the switch all that much. i hear you, but 100ll can handle more than 155psi, that's where i am at. ;-) 1 Quote
Ayesully810 Posted July 29, 2017 Report Posted July 29, 2017 29 minutes ago, ClaudeMachining said: i hear you, but 100ll can handle more than 155psi, that's where i am at. ;-) you also thought you were at plus 4 timing last year too lol jk Quote
ClaudeMachining Posted July 29, 2017 Author Report Posted July 29, 2017 21 minutes ago, Ayesully810 said: you also thought you were at plus 4 timing last year too lol jk lol, yeah that's a funny one Quote
87sheerips Posted July 29, 2017 Report Posted July 29, 2017 My old alky engine was SO picky on plug gap and a friend of mine called it out. Tightened gap and I went from frustrated to wheelie madness. 1 Quote
ClaudeMachining Posted July 29, 2017 Author Report Posted July 29, 2017 Dunno what happened, the engine is ok, no damage.Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote
375hp banshees Posted July 29, 2017 Report Posted July 29, 2017 20 minutes ago, ClaudeMachining said: Dunno what happened, the engine is ok, no damage. Envoyé de mon SM-G935W8 en utilisant Tapatalk that sucks ...weak spot from bung weld? Quote
ClaudeMachining Posted July 29, 2017 Author Report Posted July 29, 2017 22 minutes ago, 375hp banshees said: that sucks ...weak spot from bung weld? Probably. Quote
ClaudeMachining Posted July 31, 2017 Author Report Posted July 31, 2017 Hope it will hold...Envoyé de mon SM-G935W8 en utilisant Tapatalk Quote
kawa110 Posted July 31, 2017 Report Posted July 31, 2017 I hope you didn't pay for the weld job.Word!!! Quote
