ok so just put my new 4mil an .080 over together today, it has a cool head, +4 timing, k&n's, stock carbs,T5's. billit clutch
so got it together and it fired off in one kick  :blink: idle's great, throttle response is great, no leaks, no funny sounds, every thing seems great.
she purrs like a kitten.
BUT i look back and there is more smoke coming out one exhaust then the other, and one pipe is heating up like what seems normal and the other is cooler. got out my temp. gun and the cooler pipe is 25-30 degrees cooler then the other.
i tried swapping in new plugs no change.
i road it up an down my street and it has way more power then before (stock)
but after 4 heat cycles and a short ripp on my street, still one side way colder then the other by 30 degrees.
i have not done a compression test yet. or a leak down test, i dont have those tools yet i will be getting them tomorrow.
it has new pistons/rings in new bore?
what should i do if it don't pass a compression or leak down test?
split cases and start over?
  • 1 month later...
