yamaha04 Posted January 21, 2017 Report Posted January 21, 2017 Hey guys. Dented my Toomey pipe. If reasreched a few methods. I will try the freezer method first. But had a question about the heating with air pressure method. My dent isn't to bad. But needs fixed. My worry is I will ruin my chrome I have T5's that have been rechromed and they are simply beautiful. Will heating cherry red with map gas ruin my chrome ?? Quote
Gemeiner Posted January 21, 2017 Report Posted January 21, 2017 Ya thatd definitely discolor it atleast. Not sure what else itd do Sent from my SM-N920V using Tapatalk Quote
bigweav81 Posted January 21, 2017 Report Posted January 21, 2017 Saw a video somewhere on the net where a guy used a pressure washer set up.....worked well Imo. Sent from my SM-S820L using Tapatalk Quote
hoppedupandcutdown Posted January 21, 2017 Report Posted January 21, 2017 Saw a video somewhere on the net where a guy used a pressure washer set up.....worked well Imo. Sent from my SM-S820L using Tapatalk I saw that video and was fairly impressed. Does anyone know why or if water pressure would do a better job than air pressure? Quote
hoppedupandcutdown Posted January 22, 2017 Report Posted January 22, 2017 While I completely understand that, does it matter since its the pressure pushing the dent? I mean, take a combustion cylinder with water in it, and the rod bends, the force actually comes from elsewhere. I mean, my shop air would split a pipe for sure if I could seal the ends proper. Do you not think he used a pressure washer just because it's what he had available that built pressure? Quote
bigweav81 Posted January 22, 2017 Report Posted January 22, 2017 I'll try to dig up that vid. Not sure where I saw it. Sent from my SM-S820L using Tapatalk Quote
hoppedupandcutdown Posted January 22, 2017 Report Posted January 22, 2017 I guess I need a dented pipe for testing. Well, a pipe, I think I can make dents. Quote
sheerider11 Posted January 22, 2017 Report Posted January 22, 2017 Heating it will ruin the chrome. Do not freeze it. You cant concentrate the force of the ice. You can crack the pipe. 1 Quote
Tedder Posted January 22, 2017 Report Posted January 22, 2017 Here you go https://www.youtube.com/watch?v=F7o-MSOES1M 2 Quote
J-Madd Posted January 22, 2017 Report Posted January 22, 2017 Here you go https://www.youtube.com/watch?v=F7o-MSOES1M Definitely safer than air. There are some holes in my shop ceiling from the air method. (I did not do it) Quote
special06shee Posted January 22, 2017 Report Posted January 22, 2017 I did the ice thing probably 10yrs ago. Went from a quarter size dent to a 6" split 1 Quote
